Pipo P1 stock firmware
2014/06/27 - 17:15
The firmware can be found here: http://pan.baidu.com/s/1fEweq
RK3288Loader_uboot: http://crewrktablets.arctablet.com/?wpfb_dl=1883
rk30xxnand_ko.ko.3.10.0: http://crewrktablets.arctablet.com/?wpfb_dl=1882
Kernel 3.10.0 xjh #303 preempt 18.06.2014: http://crewrktablets.arctablet.com/?wpfb_dl=1884
Parameter:
FIRMWARE_VER:4.4.2
MACHINE_MODEL:P1
MACHINE_ID:007
MANUFACTURER:RK30SDK
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3288
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
#KERNEL_IMG: 0x62008000
#FDT_NAME: rk-kernel.dtb
#RECOVER_KEY: 1,1,0,20,0
CMDLINE:vmalloc=516M CMDLINE:console=ttyFIQ0 androidboot.hardware=rk30board
androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init initrd=0x62000000,0x00800000
mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),
0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),
0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),
0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00100000@0x00092000(system),
0x00002000@0x00192000(metadata),0x00400000@0x00194000(userdata),-@0x00594000(user)
Build.prop:
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=KOT49H
ro.build.display.id=rk3288-eng 4.4.2 KOT49H eng.ljh.20140620.161647 test-keys
ro.build.version.incremental=eng.ljh.20140620.161647
ro.build.version.sdk=19
ro.build.version.codename=REL
ro.build.version.release=4.4.2
ro.build.date=Fri Jun 20 16:17:46 CST 2014
ro.build.date.utc=1403252266
ro.build.type=eng
ro.build.user=ljh
ro.build.host=mid-server
ro.build.tags=test-keys
ro.product.model=P1
ro.product.brand=PIPO
ro.product.name=rk3288
ro.product.device=rk3288
ro.product.board=rk30sdk
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=rockchip
ro.product.locale.language=zh
ro.product.locale.region=CN
ro.wifi.channels=
ro.board.platform=rk3288
# ro.build.product is obsolete; use ro.product.device
ro.build.product=rk3288
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=rk3288-eng 4.4.2 KOT49H eng.ljh.20140620.161647 test-keys
ro.build.fingerprint=rockchip/rk3288/rk3288:4.4.2/KOT49H/eng.ljh.20140620.161647:eng/opinions-on-teclast-p90hdst-keys
ro.build.characteristics=tablet
# end build properties
# from device/rockchip/rk3288/system.prop
# system.prop
#rild.libpath=/system/lib/libreference-ril.so
#rild.libargs=-d /dev/ttyUSB2
# Default ecclist
ro.ril.ecclist=112,911
ro.opengles.version = 131072
wifi.interface=wlan0
rild.libpath=/system/lib/libril-rk29-dataonly.so
rild.libargs=-d /dev/ttyACM0
persist.tegra.nvmmlite = 1
ro.audio.monitorOrientation=true
#NFC
debug.nfc.fw_download=false
debug.nfc.se=false
#add Rockchip properties here
ro.rk.screenoff_time=60000
ro.rk.screenshot_enable=true
ro.rk.def_brightness=200
ro.rk.homepage_base=http://www.google.com/webhp?client={CID}&source=android-home
ro.rk.install_non_market_apps=true
sys.hwc.compose_policy=6
sys.wallpaper.rgb565=0
sf.power.control=8847360
sys.rkadb.root=0
ro.sf.fakerotation=false
ro.sf.hwrotation=0
ro.rk.MassStorage=false
ro.rk.systembar.voiceicon=true
ro.rk.systembar.tabletUI=false
ro.rk.LowBatteryBrightness=true
ro.tether.denied=false
sys.resolution.changed=false
ro.default.size=100
persist.sys.timezone=Asia/Shanghai
ro.product.usbfactory=rockchip_usb
wifi.supplicant_scan_interval=15
ro.factory.tool=0
ro.kernel.android.checkjni=0
#set default lcd density to Rockchip tablet
ro.sf.lcd_density=320
ro.adb.secure =0
# ADDITIONAL_BUILD_PROPERTIES
dalvik.vm.heapstartsize=16m
dalvik.vm.heapgrowthlimit=192m
dalvik.vm.heapsize=512m
dalvik.vm.heaptargetutilization=0.75
dalvik.vm.heapminfree=512k
dalvik.vm.heapmaxfree=8m
dalvik.vm.lockprof.threshold=500
dalvik.vm.dexopt-flags=m=y
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.hwui.texture_cache_size=72
ro.hwui.layer_cache_size=48
ro.hwui.path_cache_size=16
ro.hwui.shape_cache_size=4
ro.hwui.gradient_cache_size=1
ro.hwui.drop_shadow_cache_size=6
ro.hwui.texture_cache_flush_rate=0.4
ro.hwui.text_small_cache_width=1024
ro.hwui.text_small_cache_height=1024
ro.hwui.text_large_cache_width=2048
ro.hwui.text_large_cache_height=1024
ro.hwui.disable_scissor_opt=true
persist.sys.ui.hw=true
ro.com.android.dateformat=MM-dd-yyyy
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.notification_sound=pixiedust.ogg
ro.carrier=unknown
ro.config.alarm_alert=Alarm_Classic.ogg
ro.setupwizard.mode=OPTIONAL
ro.com.google.gmsversion=4.4_r3
keyguard.no_require_sim=true
ro.com.android.dataroaming=true
ril.function.dataonly=1
persist.sys.strictmode.visual=false
dalvik.vm.jniopts=warnonly
ro.rk.bt_enable=true
ro.rk.btchip=broadcom.bplus
ro.factory.hasUMS=true
persist.sys.usb.config=mass_storage,adb
testing.mediascanner.skiplist=/mnt/internal_sd/Android/
ro.factory.hasGPS=false
ro.factory.storage_suppntfs=true
ro.factory.without_battery=false
ro.product.version=1.0.0
ro.product.ota.host=www.jinson.com.cn:2300
persist.sys.dalvik.vm.lib=libdvm.so
ro.kernel.android.checkjni=1
net.bt.name=Android
GPU driver for Mali T-764:
mali_kbase.ko
libGLES_mali.so
admin, Johnnyb119
2014/06/27 - 19:12
If somebody like to do the first customer build - feel free ;-)
Sagformas
Spain
2014/06/29 - 09:21
Hi Oma, I'm Sag Forum bq, I'm working to bring the pipo to p1 RK31 firmware, can you help? :)
2014/06/29 - 09:33
What do you like to do exactly?
Sagformas
Spain
2014/06/29 - 09:48
To use the stock rom P1 Pipo in RK31
2014/06/29 - 09:54
This is another useless KitKat build. Not worth to do anything with it.
Sagformas
Spain
2014/06/29 - 10:01
¿multi window 2.0 rockchip?
Sagformas
Spain
2014/06/29 - 10:03
the pipo p1 stock include multi windows :
Sagformas
Spain
2014/06/29 - 11:04
The rom starts but stop in the bootanimation, five minutes ... and nothing, the logcat says that the libcutils.so is failed, I has tried to replace this lib but the tablet restarts in the kernel image.
Sagformas
Spain
2014/06/29 - 11:45
I am uploading the pipo p1 rk31 base for you, the Rom starts and charges the bootanimation, the 3.0.36 is OK, but stops in the bootanimation...also upload the logcat file, if adds the rest of the rk3288 libs the result is same.
Sagformas
Spain
2014/06/30 - 19:00
Interestingly this is not a selinux build/kernel. So this could work under gen1 loader.
Looks like this is a mounting problem. Framework, patition layout, mounts and permissions are not in line. Try to analyse whats going on in recovery and boot.
Also be careful with the 3.10.0 rknand and modules.
Sorry, I have not much time for such experiments. Good luck!
Sagformas
Spain
2014/06/30 - 21:30
The problem is in the framework folder
PrEzi
Forum Posts: 57
2014/07/03 - 22:00
Hallo Oma,
Ich habe mir gerade dem PIPO P1 3G Modell bestellt, kommt im ca. 7 Tagen.
Gilt dies Firmware auch für die 3G Version ?
Was hasst du da verbessert, bzw. verändert im Vergleich zu Stock ?
87 Guest(s)
Devices in use: Desktop (60), Phone (26), Tablet (1)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
