pipo-p1-3gwifi-cm12-1-LightVersion-no-gapps-firmware-20160117
pipo-p1-3gwifi-cm12-1-LightVersion-no-gapps-firmware Build#LMY49F 2016-01-16
mussonero1
Forum Posts: 350
Thanks Received: 70
2016/01/17 - 20:58
Use AndroidTool v2.3 or higher to update PIPO P1_3G with the update.img
After the installation of the update, the device will boot in recover mode “TRWP RECVERY”
Go to wipe and do factory wipe,
To format the internal_sd, go to wipe menu and chose advance, from it select the internal_sd partition and formatted.
Reboot the device and enjoy CM12.1 Light version.
To install google store, download GAPPS from cyanogenmod and installed form the recovery.
update.zip
https://www.4shared.com/zip/-ELqvbO7ba/CM121_PIPO-P1-3G--LightVersion.html
preview of cm13 on pipo
The following users say thank you to mussonero1 for this useful post:
Oma7144, Cytryn
JEssicannn
Forum Posts: 252
2019/10/23 - 02:08
71 Guest(s)
Devices in use: Desktop (65), Phone (6)
desluk
cimoral
merlin077
nrod
midnight-gr
Pajaro047
