PIPO-P1-3G-CM13-LightVersion-no-gapps-2016-01-27
mussonero1
Forum Posts: 350
Thanks Received: 70
2016/01/27 - 22:21
There is a new version released you can read about it here .
http://www.arctablet.com/blog/forum/rk3288-entwicklung-und-customroms-development-and-croms/cm13_pipo_p1_3g_m_final_revised_edition
Mussonero
Update for the M version 2
This update include all the previews patches and fixes ,plus new feature has been added as well.
Fix for Wifi display option , Gps fix integrated , Fixed sensors reading .
released 20/7/2016
Download linkhttps://mega.nz/#F!uYM1jYAJ!HCXg6HrkXvN94m44xGJeCA
Download link: http://crewrktablets.arctablet.com/?wpfb_dl=2908
Best regards
Mussonero
This update include many fixes and improvement, you can see some of this feature here in the video below, this video is a Preview and dose not include all the new feature just some of them, in the updated M version a lot of fixes has been added ,for an example the kernel now compiled with the new GCC 6.0.1 , soft sound volume in the bar navigation,,,,etc
Note: regarding tap2wake functionality:
If you close the tablet by pressing the power button, tab2wake will be disabled and will not wake-up the tablet,
it will work only if the "display screen" went off by it self or by taping 2 times on the statues bar to close the display screen.
Best regards MussoNero
M version update for PIPO P1 3G released 15/6/2016
Download Link: https://mega.nz/#F!qRkliTrY!Lsois6no2F7dDUC_FtkCQw
Download Link: http://crewrktablets.arctablet.com/?wpfb_dl=2881
Here is a M add-on , for the updated M-version, this will add a cool boot-sound and an update for the recovery as well.
To disable the boot sound ,edit the line "bootsound=" in the build prop .
Please install this update via TWRP recovery.
Fixed the sound issue , So please re-download the file.
M add-on Download_FIX Link: https://mega.nz/#!HM0WyILZ!TbRRocakkAMOKKhexvt87GCfJp6N7Gs7G8i7dEEKkjg
This will fix the WiFi-AP in Tethering mode.
Please flash this fix via recovery .
Download linkhttps://mega.nz/#!KU1RUJCT!h-3KN7F58DsawBH1vv0EbayOKxdLlXGP0FQyP1gkwfE
Big update regarding the kernel.
Fixed the "RTC-Device" wake-up clock issue, the alarm will wake-up the system from deep sleep mode, this also fix the system clock when there are new events in future need to be updated.
Fix annoying sound problem, now you can dump the codec via proc/driver/ .
Fixed battery voltage states and integrated the temp sensor with the battery_driver as well .
Recompiled  the Kernel  with the new Gcc 6.1.0, now it is smaller in size and faster 🙂 too.
Download linkhttps://mega.nz/#!WJFUSQ6T!3_lfbM2VnOs1sLSAYVHPHrZz005sGSrHrHEikMJ0YDs
Gps fix add-on
This will fix the GPS and Bluetooth icon issue , no more Bluetooth icon ON, when using the builtin GPS device  🙂 .
Download linkhttps://mega.nz/#!fEU2HDQZ!HMoyXP79gQEcUHEZxgDcCXyowiR9r90wHFmoXJS6jzk
Final  M version released for cm13 pipo p1_3g
this is a final build for PIPO P1 3G released 14/4/2016
This is a lite version of CM13 , no google apps installed in it.
Howto update:
Use AndroidTool v2.3 or higher version to install CM13 on PIPO P1_3G tablet,
After the successful installation, the device will reboot into recovery mode “TRWP RECOVERY” automatically.
Go to wipe option and do factory wipe, after do a manual format for the internal_sd  >> "go to wipe menu and chose advance, From it select the internal_sd partition and formatted" .
In TWRP 2.8.7.0.1 or v3.0.0 after factory wipe ,don't forgot to format Data partition manually ,you need to format it not wiping it.
Reboot the device and enjoy CM13 Light version.
To install google store, download Open-Gapps from cyanogenmod and installed form the recovery.
Best RegardsSmile
MussoNero
M final release : update  14/4/2016
what is new: in this release :
some improvement in kernel.
added latest cm13 patches .
increased the sound volume ,no need to another third part apps to do it.
added new battery states " still in beta phase"
when the device in air-plain mode the modem will be completely disabled to save more battery power.
re-added cpuquite function , it will activated when the screen is On and deactivated when they screen is OFF or in deep sleep mode.
google apps pre installed
Note1: the archive is split in 5 pieces, so please download all the 5 files.
Note2: for P1_WiFi users they need to reinstall   Oma_RK32_P1_WIFI ONLY for cams_fix .zip
Download M final version link
https://mega.nz/#F!HJdG3ChI!fgLvwIGEjA_O0cOJxsHWWQ
M Kernel : update  05/4/2016
what is new: in this kernel :
Added new deep sleep mode state "note: this mode test only with pipo p1 3g version"
Fixed modem statues issue and added a auto suspend mode
Added and fixed the cover sensor for pipo p1 3g "if you have an original pipo p1 tablet cover, it should work with this kernel update"  link video preview
Please flash this kernel via TWRP
https://mega.nz/#!KQFyFS5Z!B8jhDsDu5WflxuZicW5ci0XZM2tIGzGfjb3hN1P_Jf0
M version: updated  15/3/2016
this is a all in one version, with latest updates .
http://crewrktablets.arctablet.com/?wpfb_dl=2844
https://mega.nz/#F!WZMwDIyC!xqPet3Vbt0bUZsHlrvyowQ
Note1: the archive is split in 3 pieces, so please download all the 3 files.
Heads up: 5/3/2016
New OTA version is ready to be installed on V1.3, V1.4  and V1.5 , please install this ota from TWRP recovery.  Thanks.
Download   OTA CM13 for P1_3G_Version 1.1
Note: for P1_WiFi users they need to reinstall   Oma_RK32_P1_WIFI ONLY for cams_fix .zip
what is new:
 -- Fixed some codecs issues
-- SElinux disabled in this build.
-- updated with latest patches from Cyanogenmod.
note: 10/3/2016
After flashing the OTA CM13 V1.1  re-flash this kernel update to avoid the black screen problem .
Heads up: 27/2/2016
update for widevine  courtesy of OMA   RK32_CM13_widevine_fix
Heads up: 21/2/2016
OTG fix please flash the kernel.img,resource.img and boot.img before upgrading or after, be aware this kernel is still experimental for p1_WiFi and p1_3g ,In later releases after v1.3 the fix will be included.
Download otg_fix.zip
Download Oma_RK32_P1_WIFI ONLY for cams_fix .zip
Downloads:
Version V1.5     Updated 25/2/2016
https://mega.nz/#!TQsAyAiK!zBj3pOfqT8Bu5FGGAW8ZKSodw9hQgylq4wUIDJbGe5c
What is new in this release?
--Fixed YouTube and XBMC not playing videos with HW acceleration, now you can watch full4k YouTube video in full glory with HW acceleration. Thanks to mv_b and giaur500 for singling of the problem
--More fixes to the OTG
--Include the non-SOD kernel with 48 MHz enabled
--for P1 WiFi  you need to Download Oma_RK32_P1_WIFI ONLY for cameras_fix .zip
-- Custom recovery TWRP 3.0.0.0 updated with OTG support included.
old gallery
NOTE: if any one having issue again with SOD please Download P1_fix_OTG_And_SOD_48hz_v1.5a_twrp.zip
and flashed via TWRP.
Version V1.4     Updated 22/2/2016
http://crewrktablets.arctablet.com/?wpfb_dl=2828
https://mega.nz/#!TEcUHKIJ!Y92TPl-rru2hLcaBRP9bwT5k9GfAxhGGNQ1u8p5s-Aw
-- OTG fix, included for external USB-Stick and USB-Hdd
-- updated the kernel with non SOD issue for P1 WiFi & 3G,, thanks to dprimic & mv_b
-- small fix to the codecs
--for P1 WiFi the need to Download Oma_RK32_P1_WIFI ONLY for cameras_fix .zip
-- reworked the  HDMI option.
-- Custom recovery TWRP 3.0.0.0 updated with OTG support.
old gallery
Version V1.3     Updated 18/2/2016
http://crewrktablets.arctablet.com/?wpfb_dl=2824
https://mega.nz/#!TY0hmLoI!gmxCN701wYrKmR-6hozGMWGh63ZzrpNJErczRUyMTt8
-- Custom recovery TWRP 3.0.0.0 included in the update.
old gallery
Version V1.2     Updated 14/2/2016
http://crewrktablets.arctablet.com/?wpfb_dl=2815
https://www.4shared.com/zip/vJZYFoznce/Pipo_P1_3G_CM13_Lite_version_.html
--Back to root, almost CM13 vanilla release for RK3288 PIPO P1
-- Custom recovery TWRP 2.8.7.0.1 included in the update.
-- support for more audio and video codecs.
--Unified storage
old gallery
Version V1.1     Updated 1/2/2016
http://crewrktablets.arctablet.com/?wpfb_dl=2790
https://www.4shared.com/zip/jm_5FMTnba/CM13-Rk3288-Pipo_P1_3G--Ver11-.html
– custom recovery TWRP 2.8.7.0.1 with significant changes, included in the update.
– fix for homebrew p1_3g kernel & WiFi updated , included in the update .
– unified storage & sleep mode fix .
- updated cm13 ROM with latest patches .
- battery temp&percentage added to the ROM
- cpu temp fix in recovery mode Twrp .
Version V1      Updated 27/1/2016
http://crewrktablets.arctablet.com/?wpfb_dl=2784
https://www.4shared.com/zip/p9Os8kkvce/CM13_Rk3288_Pipo_P1_3G-Ver10-2.html
feature=youtu.be
Note:
If you have some issues regarding the kernel please proved some useful logs .
The Rom can be ported to other devices as well :).
Updated Kernel 29/01/2016:
this update work well with pipo p1 cm13 version 1......   Kernel_cm13_update.zip
How-to update the kernel:
boot the tablet in boot-loader mode and use AndroidTool v2.3 to re-flash the files included in Kernel_cm13_update.zip
Updated Recovery 31/01/2016:
this is first release of TWRP recovery for Pipo-P1 cm13 version 1..... Recovery_cm13_update.zip
How-to update the Recovery:
boot the tablet in boot-loader mode and use AndroidTool v2.3 to re-flash the files included in Recovery_cm13_update.zip
how-to update your tablet if you are on previews version of  cm13 for pipo p1_3G_or_wifi
1) lunch AndroidTool 2.3 and without pressing lower format to preserve the partition layout, press run to upgrade.
2) the device will reboot in TRWP.
2) In TWRP recovery don’t make any format to data partition, just reinstall Gapps and if you have P1_wifi then you need to reinstall the camera_fix_by_oma, and finally do wipe dalvik/cache and reboot to the system.
Screenshot_20160129-192721.pngImage Enlarger
 Screenshot_20160129-192119.pngImage Enlarger
   New look  😉
IMG_20160201_000920.jpgImage Enlarger
IMG_20160201_001029.jpgImage EnlargerIMG_20160201_000958.jpgImage Enlarger
Screenshot_20160221-062638.pngImage Enlarger
The following users say thank you to mussonero1 for this useful post:
Oma7144, Cytryn, AlexGadget, PrEzi, admin
mussonero1
Forum Posts: 350
Thanks Received: 70
2016/02/01 - 21:36
The temp have been exposed to PIPO P1 3G 🙂
Screenshot_20160201-212641.pngImage EnlargerScreenshot_20160201-212705.pngImage Enlarger
jackoski
2016/02/07 - 14:49
Hi
Thanks for you work
I install your mod v1.1 and open gaps
but my tablet not to wake up from sleep mode.
sorry for my English i use gogle translator 🙂
mussonero1
Forum Posts: 350
Thanks Received: 70
2016/02/07 - 15:09
jackoski said
hi
are you using P1 wifi ? or the 3G? version.
jackoski
2016/02/07 - 15:16
i have pipo p1 3g
mussonero1
Forum Posts: 350
Thanks Received: 70
2016/02/07 - 15:37
jackoski said
i have pipo p1 3g
Ok perfect, ,,  can you send me the dmesg  and logcat please.
use kernel auditor app to get the dmesg and logcat .
thanks
jackoski
2016/02/07 - 16:10
The following users say thank you to jackoski for this useful post:
mussonero1
mussonero1
Forum Posts: 350
Thanks Received: 70
2016/02/07 - 16:54
jackoski said
thanks i will look for more solutions and keep you posted .
jackoski
2016/02/07 - 17:28
mussonero1 said
Thank you and best regards
dprimic
Forum Posts: 63
2016/02/08 - 21:19
I would like to downclock to 1.6. Tried with Setcpu but didn't work? Any suggestion?
dprimic
Forum Posts: 63
2016/02/08 - 21:36
I just realized that min cpu frequancy is 600. Is that normal for this rom?
mussonero1
Forum Posts: 350
Thanks Received: 70
2016/02/08 - 21:38
down-clocking it is not possible at this point, and dose not not make any sense, the pipo p1 stock kernel use 1.8ghz ,, so it is safer at 1.8ghz.
but if you know, how to work around the resource.img you can modded manually .
mussonero1
Forum Posts: 350
Thanks Received: 70
2016/02/08 - 21:43
no, the minimum is 216mhz .
dprimic
Forum Posts: 63
2016/02/08 - 22:11
Sometimes my pipo p1 (wifi) restart at 1.8. It is probably an aberation. I understand that the min frequancy is 214. On my Pipo 214 is listed also but never go bellow 600 and always are all cores at least at 600 (interactive governor). Do you have any other compatible kernal to test?
mussonero1
Forum Posts: 350
Thanks Received: 70
2016/02/08 - 22:24
can you post some screen shots of the cpu states from the kernel auditor .
53 Guest(s)
Devices in use: Desktop (50), Phone (3)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
