2013/02/28
Hi
I have installed this version, and it is up and running, i can browse the internet but when i go to google play most of the time it says I'm offline, but if i manage after some time to download some apps it refuse to set them up and come up with error code 960 or similar.
Any idea why this is?
Best regards
form
If you have root, then uninstall GooglePlaystore ( Phonesky) and GooglePlayServices (GMSCore) the latest Playstore version is v 6.2.10 and Google PlayServices is 8.7.01. I guess ( maybe I am wrong) but I do faced this problems once in awhile when modding ROM and installing a wrong version ( mismatch version between GMSCore and Playstore) before uninstalling please visit http://www.apkmirror.com/apk/google-inc/ Â to get all the latest pre-released and past version of Google apps and download the required apps.Then you can uninstall and reinstall these apps.
About Me  LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
Which tab? Which build?
Curious, works flawlessly here. Anyway, you will find latest Android 6.0.1 gapps here: http://forum.xda-developers.com/android/general/gapps-gapps-6-0-1-minimal-t3276606
Pls use latest build v1.2.4b and install the gapps via TWRP.
No, it is enabled per default in build v1.2.4b. However, it is not necessary to flash the loader when you come from LP.
62 Guest(s)
Devices in use: Desktop (54), Phone (8)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
