CM12.1 build is out: http://crewrktablets.arctablet.com/?p=5397
Unfortunately KK kernel won't work anymore. So, one need a LP kernel. If kernel sources are available for the tab this should be no problem.
LX_RPer aspera ad astra, we rock the Tablets !
2015/02/12
Any news on this? I finally got my Teclast P90HD back from repair and I was wondering if somebody has been able to install CM12.1 on it? So far there is only a Beta of Omni ROM. Is there way to port a Cyanogenmod ROM from another RK3288 Tablet? How many P90HD owners are here in this board?
2015/02/12
Unfortunately Teclast did not publish kernel sources. So, we a trapped with KK. Sorry.- Oma -
Don't you dare apologize! You are the hero of this board. It is not your fault that the after sales support of chinese tablet manufacturers is terrible. I was just wondering if you could maybe extract the "driver" for the display from this ROM for example, since it has the same display and mix it together somehow (sorry if that sounds stupid): http://forum.xda-developers.com/kindle-fire-hdx/development/rom-cm-12-unofficial-apollo-thor-t3050199
No. I kernel is a binary that needs to be compiled from source code. No code := no party.
Pls use the latest multi-windows build and use the Xposed framework to customize the build. You will have the same functionallity then in CM builds and more 😉
2016/04/02
Hi Oma
I ported you cyanogen 12.01 pipo9 to my tv-box rk902-ii. its work, but without sound support (((
pipo9 kernel dont support rk1000 sound card im my tv-box.
Can you created kernel for support RKM 902-ii (rk3288cpu) tv-box to you cyanogen images ?
Or also have little questions. You kernel support cpu-temperature (thermal).
How to do it? can give patch for it?
I enable all in kernel config file for support thermal mode, also i do last patched termal drivers
but my cpu-temperature always 2 celsium (
Can help me?
This my worked kernel and resource configure for my 5.1 android (for firefly 5.1 source)
2015/02/12
Pls use the latest multi-windows build and use the Xposed framework to customize the build. You will have the same functionallity then in CM builds and more 😉- Oma -
Thank you for your tip! One last question: I have the A6K7 Revision and was wondering, if there is a ROM version 2.2 (with Android 4.4.4) available, since it is the newer version of the tablet.
There are huge issues with the creepy Teclast kernel. There is no way (no reset or the like) to easily bring back the tab to bootloader mode when something crashes. I do only have the A6K6 to hold the risk on my side. So, I strongly recommend to use what has been verified by other user. And btw there is no noticeable advantage of 4.4.4 on tabs like the Teclast.
Great! You need to compile the HAL's for your specific Audio Chip and PMU.
2016/04/02
Hi Oma.
I have`nt you source kernel for cyanogen ( and default cyan source dont have rk3288 source)
Pipo 9 images setup in my tv-box with my resource-only modification and worked (without sound).
I compiled my kernel and it worked fine with sound in original rkm images or firefly sdk images.
But my kernel dont work in you cyagen mode- box not started. With you kernel for pipo 9 work, but no sound.
Can you compile kernel for cyanogen with my ".configure" file ? Or mayby can give me source cyanogen kernel for rk3288 pipo9 and i can modificated it for my box rk902-ii.
My email - iscan_adm@yahoo.com
Also how to cpu temperature ?
73 Guest(s)
Devices in use: Desktop (64), Phone (8), Tablet (1)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
