2014/08/02
CM13 PIPO P1 3G M FINAL REVISED EDITION #2 Released 11/8/2016
What is new;
Released 29/9/2016
This will be last release for Pipo P1 CM13 M version , since Cm14 already Landed on Pipo p1
Some screen shots for CM14 in early alpha stage https://dropshots.com/mussonero/date/2016-09-29
In this release, it is all about kernel nothing new have been added to the CM13 Os, except latest patch from CM13 source.
Added a new interrupter wakeup for the usb modem and new serial driver has been added as well ,
Added auto sim detection and power-of the modem on sim removal .
and other stuff,,,,,,
Released 11/8/2016
Fixed the audio lag issue + new option for Ambient Display.
Enabled by default sensitive to movements . you can control it via build.prop.
Added support for HW+ decoding, by default it is enabled now.
New battery driver for the battery rewritten "any issues or bugs, please report it"
More fix to the RTC ,now it is run in compatible mode withe android alarm system.
Fix the phone audio voice issue 😉 , now it is more clear than before .
Latest CM source are used here, august source.
Note: if you get the feeling of some lag issue, please check the live-display option is turned off .
Little update: for the kernel and new theme for Cm13 please flash this fix after you have flashed the full release.
Released 28/7/2016
Added new a sensor , this will be used for Ambient Display 🙂 you can read about it here, and you can even disable the new sensor via build prob , so the tablet will turn it self when you shacked or picked it up .
More fixes to GPS , no more power drain.
New option for the WiFi exposed to the users.
More fixes to tap2wake .
New fix for the hall sensor regarding the cover lid, moved the control of turning OFF/ON to the system OS.
You still can read for other added features in this previews post here.
Released 29/9/2016
Download link:
http://crewrktablets.arctablet.com/?wpfb_dl=2960
note: please redo a clean install , recommended .
Released 11/8/2016
Download link:
https://mega.nz/#F!fAdGVYrQ!twZ5Ln9jDFqGoLH0qvssJg
http://crewrktablets.arctablet.com/?wpfb_dl=2939
Little update: for the kernel and new theme for Cm13, please flash this fix after you have flashed the full release.
https://mega.nz/#!fIdWgDrQ!Nghve20VZLWDJv4Z5p6NHeWEL80ieQHDYOwT1GSt5pg
Best Regards
Released 28/7/2016
Download link:
https://mega.nz/#F!LQc3ALRR!nNRjyODwMQhhT4QYMyZrUQ
http://crewrktablets.arctablet.com/?wpfb_dl=2919
note: please redo a clean install ..
Released Add-on 28/7/2016
Add-on and FIX for the audio issue" " plus new option for Ambient Display
you need to add this line to your build.prop, if you want to active the sensor in "low more or high mode " sensitivity .
enable.low-mode=true , if you want it like picking-up or shaking up the tablet.
enable.low-mode=false , if you want more sensitive to movements .
Download link for audio_lagging_fix and the new sensor option
https://mega.nz/#!TYFSAaLT!mGdvpEHYKqH7kT5O9EG-OUvDHUjJiD7p7lVXC8N5PJ4
Best Regards
This is for PIPO P1 Tablet 3g model
Howto update:
Use AndroidTool v2.3 or higher version to install CM13 on PIPO P1_3G tablet,
After the successful installation, the device will reboot into recovery mode “TRWP RECOVERY” automatically.
Go to wipe option and do factory wipe, after do a manual format for the internal_sd >> "go to wipe menu and chose advance, From it select the internal_sd partition and formatted" .
In TWRP v3.0.2 after factory wipe ,don't forgot to format Data partition manually ,you need to format it, do not wipe it normaly.
Reboot the device and enjoy CM13 REVISED .
Best Regards
MussoNero
The following users say thank you to mussonero1 for this useful post:
Oma7144, admin, Teeo1972, iav, PrEzi
2014/08/02
2014/08/02
2014/08/02
New update released
Released 11/8/2016
Fixed the audio lag isssue plus new option for Ambient Display.
2014/08/02
Best Regards
2014/08/02
dcll222 said
I have a Pipo P1 Wifi model, could I flash this ROM?
Yes you can, but if you could not get the camera working, you need to install this fix
2016/08/19
Thanks a lot. I will try it.
2016/08/23
Teeo1972 said
Hi!I have used this firmware for some days now and I have only noticed one issue so far. After the tablet goes to sleep, it wont wake up again. I have to do a reset (hold the power button >10s ) and after that it starts again.
Anyone have this issue and a resolution?
Just installed this and seems that I'm encountering exactly the same problem. I actually had to use the reset button on the back to get it to start again but it seems to be working just fine afterwards. I'm using the WiFi version if that matters.
The following users say thank you to Veko for this useful post:
iav
2016/08/23
Just read the previous thread and it seems that this is an old problem which seems to be hard to fix.
Installed CPU Awake and it seems to be able to block the deep sleep. My old ROM couldn't do deep sleep either so no functionality lost there. On the other hand, everything else is just awesome! Loving CM13 when compared to the old KitKat, thanks for doing this mussonero! 🙂
Teeo1972, iavMost Users Ever Online: 803
57 Guest(s)
Devices in use: Desktop (49), Phone (8)
