CM12.1 has landed on rk32board 😉
CrewRKTablets RK32 Air CM12.1 build v1.2.1
kernel update: (change in folder rockdev/Image before flash)
kernel #24 - perfect battery stats
kernel #33 - CPU @ 1.8 GHz
3G fix by mussonero (install zip via TWRP)
CrewRKTablets RK32 Air CM12.1 beta build v1.2
CrewRKTablets RK32 Air CM12.1 beta build v1.1
CrewRKTablets RK32 Air CM12.1 test build v1.0
– stock recovery 5.0.0 [v1.0, v1.1]
– CrewRKTablets recovery CWM 6.0.5.1 [v1.2.1]
– kernel #10 [v1.0, v1.1]
– kernel #19 [v1.2, v1.2.1]
– unified storage [v1.2, v1.2.1]
– Reboot Menue
not working:
- video recording with cam
hints:
– Oma's favourite apps for LP (install via apk installer)
– Xposed framework test pack
further hints to improve UI feeling:
- disable all animation scales in developer options,
- use Nova launcher and set animation/scroll to “faster than light” and
- enable Entropy Fixer with value 256
Special thanks to netlars !
Ok, now the hwcomposer for a better UI feeling. Install via TWRP: http://crewrktablets.arctablet.com/?wpfb_dl=2610
Further hints to improve UI feeling:
In stock the internal storage (app space) is only 1 GB. The remaining free space on the NAND is used for the internal sdcard.
2015/02/14
I did it twice. I went back to your previous ROM - you can see there internal storage (about 4G) and nand flash (about 24G). Together is equal to 32G (after format). But in your screenshot I see only internal 4G storage and 32G external microSD card (29.27GB after format)...
Can you explain what happened to the missing internal memory ?
Interestingly Xposed framework works ... hm, just playing around 😉
If somebody would like to test: http://crewrktablets.arctablet.com/?wpfb_dl=2629
Brightness settings fix (install via TWRP): http://crewrktablets.arctablet.com/?wpfb_dl=2634
Update post#1 with release build v1.2.1
- fixing brightness settings
- add RKVideoPlayer
- add some CM12.1 themes
- more generic approach to roll out on other tabs:
- includes TWRP's for different screens and CWM
- includes test stuff for HDMI, 3G and GPS
Confirmed installations:
- change kernel/resource in folder rockdev/Image before flash
- choose right TWRP or use CWM
- first boot into TWRP/CWM: do a factory reset and install the model fix
Pipo P1: screen 2048 x 1536, 320 dpi, kernel 150, model fix
Pipo P9: screen 1920 x 1200, 240 dpi, kernel 30, model fix 2
zlodei24Per aspera ad astra, we rock the Tablets !
2014/08/02
Hi there
here is a small fix for the P1-3G not showing in "CM12.1 oma build" and not connecting to internet using the mussonero kernel #150
I made this quick fix using rild-reference library ,now internet working ,operator nameS showing normally, you can select the APN from "Data usage , click on the upper soft button and select mobile network" AND RESTART THE TABLET
what missing : gsm bar signal strength and the upper small icon 3g connection to internet 🙂
enjoy
@oma
please add the Stk package to your build it is missing.
The following users say thank you to mussonero1 for this useful post:
Oma7144Most Users Ever Online: 803
58 Guest(s)
Devices in use: Desktop (52), Phone (6)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
