[ ROM ] Nameless 2017 Deco-OCU-Altroconsumo Euro Promotion Tab Android 5.1 custom firmware request
2017/01/30 - 18:51
Last try.
kesy85
2017/01/30 - 19:07
Last try.
nothing, won't boot.
I don't know if it is important but in my stock rom if i press "switch" in android tool nothing happens, I have to boot it pressing volume down to go in to loader mode (the tablet volume keys and screen are upsidedown when turned off)
Skirttles
2017/01/31 - 09:35
kesy85 said
just to be clear, what should we flash? misc.img and twrp_test.img? nothing else?
the tablet reboots and goes directly ian bootloop.
If I'm not missing something there is no way to boot to recovery
You should flash the twrp Recovery.
To boot to stock Recovery press power button  and volume down button  at The same time until the recovery loads.
To the twrp Recovery that does not work, wont loads the twrp Recovery.
Dont flash The loader or else you'll brick the tablet because the loader its not compatible with the tablet and we dont have the "stock loader" to flash to unbrick the tablet...
Skirttles
2017/02/03 - 02:53
From Portugal there is a rom for this tablet!
DecoTab79X Multimedia Rom V1
Check here:
https://facebook.com/groups/1445781512099636
https://forum.zwame.pt/threads/deco-tab79x-8-tablet-4core-rk3126-roms.982726
Skirttles
2017/02/03 - 21:49
Rom for The tablet
https://youtu.be/vyzvXEB5fzE
Fast0n
2017/02/15 - 17:49
Skirttles said
Rom for The tablet
Warning! the firmware installed on your Tablet, there are 2 models with a processor, NAND and RAM different
DSC_5731_1.jpgImage Enlarger
VacaLeiteira
2017/02/17 - 00:29
Hi. I have a new one of this tablets (micron chips). Was anyone able to install the OMA recommended TWRP without brick or create a bootloop?
This tablet has root access via ADB. is possible to install superuser and su files successfully? I've tried (last version of supersu), without success of rooting.
the kingo root erase the original "su" file. I've made a copy of the original(su.bak in /system/xbin/ to avoid problems). Also without success.
Thanks.
Fast0n
Carontes
2017/03/10 - 03:37
I've made a TRWP that boots and works in most of all its parts. The only big problem is that it breaks the usb mass storage mounting, forever. Even flashing again the ROM. The only thing you can do is to charge the tablet. I haven't found a solution for that yet so I hope that Oma7144 could solve the problem. I'm here if anyone is interesting to try to fix it.
jmdc157
2017/03/10 - 18:33
Hi, what changes have you made? It's based on Oma's TWRP or you compiled it from sources? Could you share it? Thanks.
Carontes
2017/03/10 - 19:12
As I said it breaks the usb mounting forever, unless someone could find a fix. That's why I didn't share it. If you wanna take the risk to install it go ahead, but then don't complain me for that. It's based on Oma's TWRP and it's 800x1280. So if you don't have problems with what I said I share it
jmdc157
2017/03/10 - 19:35
Yeah, I know the risks. If you don't want to share it here you can send me a PM. About that problem, have you tried flashing a rk3126 loader and a dump? A mate had problems with the internal memory after trying to flash a modified TWRP, and flashing those fixed the problem. Specifically, he flashed this loader and this dump (dump source: https://forum.zwame.pt/threads/deco-tab79x-8-tablet-4core-rk3126-roms.982726/). Hope that it helps!
EDIT: Only flash it if you have Micron memory. If you have Hynix, search for the other dump in the thread I linked
Carontes
2017/03/10 - 19:54
Are you sure about that loader? You know that it could brick the tablet if it's wrong? I've uploaded the file. You've been warned.
jmdc157
2017/03/10 - 20:00
Yeah, we have tried that loader in three tablets and it worked. At least in Micron ones. Anyways, if you flash a wrong loader the tablet goes into maskrom mode and it's still possible to recover it.
Carontes
2017/03/10 - 20:05
Thanks. I'll try it later, hoping it could solve my usb problem. Also I've tried three different micro sd and none of them were recognised by the tablet. It's very strange. Idk if because of the SDs or because my tablet doesn't work good 😀
83 Guest(s)
Devices in use: Desktop (77), Phone (6)
cutierogue
hans41
rickybk
