Hm, do you have a dump of the stock firmware coming with your tab?
2015/07/04
It does not charge over usb. I tried with screen off and tablet off and an amp meter. It does not draw anything from the usb charger. 0.00 amps. I used and adaptor to connect the charging port to a 1 amp usb charger and it is drawing 0.60 amps so the charging port has some mechanism to detect the charging source and not try to pull 2 amps from any charger. I guess wiring the usb port +/- to the charging port will work. It will not charge faster but it will do the job.
Yes.
Can you pls check with Androsensor (see Play Store) if there is an event for accelerometer?
Can you pls check kernel #607 (see post #11)? Just copy to folder rockdev/Image and untick all boxes other than kernel/resource/uboot. Then Run.
2015/07/04
found this : http://forum.xda-developers.com/showthread.php?t=1323957
I'll test and see if I can make it work but I guess I'll need your help with a modified kernel.
86 Guest(s)
Devices in use: Desktop (73), Phone (11), Tablet (2)
avv2011
leadpan101
jumbo65
kalkpits
m12k
StatusQ
