Hard power off by Reset. Then hold Power and Reset to start the flash modus.
2015/06/22
Tried to no avail.
The Device is connected to Power and PC while doing this correct?
Power off by reset seems to work. If I then press and hold Power and reset nothing happens... if I let go of reset the device comes back as ADB device.. Switch button in Tool does seem to work but has no effect...
Other buttons just give device mismatch.
Fred
2015/06/22
Here is the logfile from when I tried to flash from Kemper build to your build:
13:17:12 416 AndroidTool v2.3.0.0 start run
13:18:26 087 Error:RKU_Read-->ReadFile failed,bRet=1,err=0,size=13,read=0
13:19:22 746 Layer<2-3>:Test Device Start
13:19:22 746 Layer<2-3>:Test Device Success
13:19:22 746 Layer<2-3>: Download parameter...
13:19:22 809 Layer<2-3>: Download uboot...
13:19:24 150 Layer<2-3>: Download misc...
13:19:24 181 Layer<2-3>: Download resource...
13:19:26 989 Layer<2-3>: Download kernel...
13:19:29 095 Layer<2-3>: Download uboot...
13:19:29 813 Layer<2-3>: Download recovery...
13:19:32 777 Layer<2-3>: Download system...
13:21:47 639 Layer<2-3>: RunProc is ending, ret=1
13:24:32 496 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:24:43 712 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:25:38 760 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:31:07 784 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:31:15 578 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:31:19 400 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:31:28 889 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:31:41 270 Layer<2-3>: RunProc is ending, ret=0
13:31:50 006 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:33:13 483 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:33:20 846 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:49:22 120 AndroidTool v2.3.0.0 start run
13:52:18 242 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:52:24 264 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:52:28 663 ERROR:SwitchAdbToRockusb-->No connect Ack received.
13:52:44 598 Layer<2-3>: RunProc is ending, ret=0
14:15:44 138 AndroidTool v2.3.0.0 start run
14:15:47 975 ERROR:SwitchAdbToRockusb-->No connect Ack received.
14:17:03 690 ERROR:SwitchAdbToRockusb-->No connect Ack received.
14:50:43 073 AndroidTool v2.3.0.0 start run
14:53:40 035 ERROR:SwitchAdbToRockusb-->No connect Ack received.
16:54:24 083 AndroidTool v2.3.0.0 start run
16:58:33 997 ERROR:SwitchAdbToRockusb-->No connect Ack received.
16:58:45 510 ERROR:SwitchAdbToRockusb-->No connect Ack received.
16:58:55 678 ERROR:SwitchAdbToRockusb-->No connect Ack received.
16:59:14 823 Layer<2-3>: RunProc is ending, ret=0
17:00:09 292 ERROR:SwitchAdbToRockusb-->Send Connect command failed
17:05:36 812 ERROR:SwitchAdbToRockusb-->No connect Ack received.
17:05:46 653 Layer<2-3>: RunProc is ending, ret=0
Any problems there?
Fred
LowerFormat is missing.
Unplug usb-cable. Press Reset. Hold Power and plug usb-cable.
The log does not show a LowerFormat. Flashing the build into the given partition sizes corrupted the images.
When there is no possibility to start into flash modus by the typical key combinations you need to open the tab to start the mask-rom modus.
In principle like here:
When there is adb connection you can try:
reboot bootloader
2015/06/22
No response... Command gets send OK but no response, I think you were right and the image is busted.
It responses to the devices command alright so there must be some basics running. Cant I sort of TFTP an Image to the Chuwi?
It should know Push and Pull commands correct?
Fred
2015/07/04
Thanks to Oma I managed to get my bricked chuwi v17HD RK3128Â back to life.
Here is what I did:
Windows 7 x64 laptop
I opened the bricked chuwi v17HD
I connected the USB cable to the pc and the Chuwi
I opened the RK flash tool (AndroidTool v2.3)
I shorted pin 8 and 9 (chip Hynix H27UCG8T2BTR). Pin 1 starts from the tablet edge side of the chip.
I pressed the reset button and voila the laptop recognized the tabled (I tried without pressing the reset button and it didn't work).
I had to install the driver included in your download package for the RK3128
I just pointed the driver update to your folder path
The driver installed
I got Mask Rom Found on the flash tool
I ticked the loader box in the RKTool
I clicked Run and a few minutes later the tablet rebooted.
I got some kind of not found message with the green droid but the tablet finished updating and rebooted
It's working now.
The following users say thank you to hadaak for this useful post:
2015/07/04
Oma,
I need a soft to move apps to sdcard in batch. I have a lot of apps. I'm using the tablet for educational purposes. in JB I used to use Link2SD but with KitKat nothing works. I tried all apps on playstore. I can move apps with the stock Settings app but this is a manual process. I need to move apps because I'm running out of internal storage space. I noticed this build has 2GB of internal storage. Does this mean you can partition the build and get any amount of internal storage or is there a limit. the chuwi is showing 2GB internal and 4.28 Nand flash. I would like to have 5.5 GB internal and the rest as external NAND. Is this possible.
Another question: I'll be buying more of the this tablet and I would like to know if there is a method (probably like you build your packages) to have a master image to deploy to other tablets with all the application and settings configured. I used to use TWRP with ICS and ainol tablets. Can I do the same for the chuwi?
I guess it charges over usb port, but only when the tab is off or screen is off.
What do you mean by screen orientation not working? No rotation or just wrong orientation?
Currently Online: mogabi
83 Guest(s)
2 Guest(s)
Devices in use: Desktop (75), Phone (8), Tablet (1)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
