[ RK3126 ROM ] Vido N70 ZZ 4.4.4 custom root firmware (2015/02/22)
Build is for RTL8189es wifi.
Thanks Received: 1385
2015/02/22 - 19:42
Gents,
This is my first build for a rk3126board ;-)
Oma N70 ZZ KitKat build v1.0
– stock recovery 4.4.2
– kernel #1 preempt 12. Jan 2015
– 2 GB internal storage
– init.d support
– full google apps support incl. Play Store
– Dateimanager HD (Root)
– Nova Launcher
hints:
 – Oma -
V17HD_20c-3.pngImage EnlargerFlashTool.pngImage EnlargerFlashTool_TWRP.pngImage EnlargerTWRP_01.pngImage EnlargerOma_RK31_Vido_N70_ZZ_KK_4.4.4_v1.0.pngImage EnlargerN70_v1.0_03.pngImage EnlargerN70_v1.0_02.pngImage EnlargerN70_v1.0_05.pngImage Enlarger
Currently Online: Nazarevich, helloyuen
81 Guest(s)
Devices in use: Desktop (73), Phone (9), Tablet (1)
jumbo65
kalkpits
m12k
StatusQ
helloyuen
melcis
