[ RK3126 ROM ] Odys Mira 4.4.4 custom root firmware (2015/02/21)
Build is for RTL8723au wifi/BT.
2015/02/28 - 19:21
Gents,
This is for Odys Mira. Build is for RTL8723au wifi/BTi ;-)
Oma Mira KitKat build v1.0
– stock recovery 4.4.2
– kernel #326 preempt 9. Dec 2014
– unified internal storage
– multi-user
– init.d support
– full google apps support incl. Play Store
– Dateimanager HD (Root)
– Nova Launcher
hints:
 – Oma -
V17HD_20c-5.pngImage EnlargerFlashTool-2.pngImage EnlargerFlashTool_TWRP-2.pngImage EnlargerTWRP_01-3.pngImage EnlargerOma_RK31_Odys_Mira_KK_4.4.4_v1.0.pngImage Enlarger
v1.0_03-3.pngImage Enlargerv1.0_02-6.pngImage Enlargerv1.0_04-1.pngImage Enlargerv1.0_06.pngImage Enlargerv1.0_07.pngImage Enlarger
v1.0_09.pngImage Enlarger
v1.0_08.pngImage Enlarger
Fear1072
2015/03/01 - 11:46
Odys Mira Specs:
- PCB: 7500-M75260-08R / 2014-10-26
- SoC: RK3126
- Screen: FPC-TP070215(708B)-03 / 2014-09-19
- Touchcontroller: Goodix GSLX680
- Wifi: Realtek 8723AU
- Audio: RK_RK312X
- Sensor: mma7660 (daemon mma8452)
- Keypad: Power=116, Vol-up=115, Vol-down=114
- Camera: gc2145_back, gc0312_front
- HDMI: ./.
- Clock: hym8563
- Flash: 1 x 8192 MB - Hynix H27UCG8T2ETR
- DRAM: 2 x 500 MB DDR3 - K4B4G1646G-BCK0
- Akku capacity: 2800 mAh
Mira_Case.pngImage EnlargerMira_open.pngImage EnlargerMira_PCB.jpgImage EnlargerMira_RK_NAND_RAM.jpgImage EnlargerMira_Wifi_Touch.jpgImage EnlargerMira_Akku.jpgImage Enlarger
Fear1072
2016/08/23 - 20:10
Where can I download ???
2016/08/27 - 08:16
See download link post #1.
Axlina
2016/09/03 - 19:11
Please telll me would this work on this tablet?
http://meanit.mobil.hr/Tablet_Q12
I tried to install xposed framework trough FlashFire, and when tab turned on i got the Stresstest has stopped and process com.phone.android has stopped (or something like that).
2016/09/03 - 19:32
Xposed framework will not work on Rockchip LP firmware, due to selinux restrictions. Is the stock firmware available or do you have a backup of the stock firmware?
Axlina
2016/09/03 - 19:40
I bought this tab yesterday, because it's cheap, so i don't have stock firmware and i couldn't install custom recovery so I don't have backup either.
Any idea what to do next? I can't send it to repair, because i lost warrany witth root. Please help.
Axlina
2016/09/03 - 19:56
Thank you. I did try that this morning , but it but I got an error. I forgot to mention that after first reboot where I got those stresstest, UI and android.com stopped working messages,  I did factory reset, and after that when tab turns on, all I see are those messages and I can't do anything. It never gets to home screen.
2016/09/03 - 20:00
Which Windows? Which error?
Axlina
2016/09/03 - 20:05
Wndows 10 and error I got was "android tool match device type failed"
It said one device found, so I hit swiitch and run and than this message comes.
2016/09/03 - 20:13
Make sure the USB driver are installed properly. Here is the latest Driver-Assitant: http://crewrktablets.arctablet.com/?wpfb_dl=2766
Typical key combination for flash-modus is Power and Vol+.
Axlina
2016/09/03 - 20:17
Well the instruction said to uninstall first and than install ,so i did it. It said drivers installed succesfully. I'll try again now.
Axlina
2016/09/03 - 20:32
i tried,power and VOL+ takes me to recovery, and POW and VOL- does nothing. Error is Match device type failed, stop running.
2016/09/03 - 20:35
Make sure you have all cable plugged before using key kombination. The FlashTool must show Loader Device.
64 Guest(s)
Devices in use: Desktop (56), Phone (8)
