[ RK3128 ROM ] Kingpad K70 4.4.4 custom root firmware (2015/05/30)
Build is for RTL8189es wifi/BT.
Thanks Received: 1385
2015/05/31 - 11:32
Gents,
This is a build for RTL8189es wifi/BT ;-)
Oma K70 KitKat build v1.0
– stock recovery 4.4.2
– kernel #83 preempt 12. Mrz 2015
– 2 GB internal storage
– init.d support
– full google apps support incl. Play Store
– Dateimanager HD (Root)
– Nova Launcher
hints:
 – Oma -
oma-1.pngImage Enlarger
FlashTool.pngImage EnlargerFlashTool_TWRP.pngImage EnlargerTWRP_01.pngImage EnlargerOma_RK31_Kingpad_K70_KK_4.4.4_v1.0.pngImage EnlargerK70_01.pngImage EnlargerK70_02.pngImage Enlarger
K70_04.pngImage EnlargerK70_05.pngImage Enlarger
Supernoob, zecchi69
Azzlaer
2017/02/04 - 22:32
LINK DOWNLOAD ?
2017/02/05 - 17:21
Server was down, sorry. Please try again.
zecchi69
2018/12/10 - 22:19
would it be possible to reload the file please ??
thanks
73 Guest(s)
Devices in use: Desktop (67), Phone (6)
lilila3
Anatrop
antoniors021
wemiy54158
sidor
houssmen
