Gents,
This is for Kempler&Strauss Playtab. Build is for ESP8089 wifi
 Oma Playtab KitKat build v1.0
– stock recovery 4.4.2
– kernel #26 preempt 7. Jan 2015
– 2 GB internal storage
– init.d support
– full google apps support incl. Play Store
– Dateimanager HD (Root)
– Nova Launcher
hints:
 – Oma -
xavierH, piwas3, gilcamtzPer aspera ad astra, we rock the Tablets !
2016/02/14
whether support for device me ???
FIRMWARE_VER:4.4.2
MACHINE_MODEL:rk312x
MACHINE_ID:007
MANUFACTURER:RK30SDK
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 312x
CHECK_MASK: 0x80
KERNEL_IMG: 0x60408000
#RECOVER_KEY: 1,1,0,20,0
CMDLINE:console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00006000@0x0000E000(kernel),0x00006000@0x00014000(boot),0x00010000@0x0001A000(recovery),0x00020000@0x0002A000(backup),0x00040000@0x0004A000(cache),0x00300000@0x0008A000(userdata),0x00002000@0x0038A000(metadata),0x00002000@0x0038C000(kpanic),0x00180000@0x0038E000(system),0x0021C000@0x0050E000(user),-@0x0072A000(oem)
58 Guest(s)
Devices in use: Desktop (45), Phone (13)
mongol
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
