Β Please donate to support OMA and CrewRKTablets firmware work, thank you !
Gents,
This is for Cube U25GT-W4. Build is for NMC1000 wifi
Β
Oma U25GT-W4 KitKat build v1.0
β stock recovery 4.4.2
β CrewRKTablets recovery TWRP 2.8.4.0
βΒ kernel #489 preempt 18. Jan 2015
β 2 GB internal storage
β init.d support
β latest hosts, su, su-binary, busybox
β full google apps support incl. Play Store
β Reboot Menue, sEFix, FX Sound
β Dateimanager HD (Root)
β Nova Launcher
Β
hints:
β to improve UI feeling: disable all animation scales in developer options,
β¦use Nova launcher and set animation/scroll to βfaster than lightβ and
β¦enable Entropy Fixer with value 256
β battery drain > set keep wi-fi on during sleep to never
β full access to the build > enable /system rw in File Manager HD
β donβt show su notifications > disable in Superuser
β to prettify the build use Xposed Framework > Starter Pack
β to enable multi-user use the Xposed module Multi User
Β
Update: the tab does not have volume rockers, so hold Power and Reset to start into flash modus.
Β
Β β Oma -
U25GT-BN is most likely not a Rockchip architekture.
Pls check with this app: https://play.google.com/store/apps/details?id=com.arctablet.cpucheck
47 Guest(s)
Devices in use: Desktop (38), Phone (9)
VMILCINOV
