Nameless 2 Euro Promotion Tab Android 4.4.4 [RK3126 and NMC1000]
Latest version of the 2 Euro promotion Tab (originally based on RK3026)
61
2015/10/14 - 17:28
Pls change the attached parameter file in folder rockdev and try again incl. LowerFormat.
62
2015/10/14 - 17:32
mballes said
I posted the screenshot in the post 53.
Ok, tab has only 4 GB NAND. So I will swap mounts with the next build.
swap_mounts.pngImage Enlarger
mballes
Forum Posts: 22
Thanks Received: 5
63
2015/10/14 - 18:01
Thank you , Oma . I 'm slowly learning from " Monsters of computer " like you.
Aron65
Forum Posts: 17
64
2015/10/14 - 18:50
 Sorry, don't work. Flash stop after few seconds.
65
2015/10/14 - 18:59
I am getting the impression this is a defective NAND. Execute the complete procedure with RKDevelopTool and then flash build v1.0 incl. the loader (tick it).
Aron65
Forum Posts: 17
66
2015/10/14 - 20:59
Pls Oma, how do you execute the complete procedure with RKDevelopTool?
Then do I flash build v1.0 incl. the loader with RKAndroidTool?
Thanks a lot!!!
67
2015/10/14 - 21:13
There is an instructions picture in the download pack of the RKDevelopTool. Follow the steps but load the rk3126 loader.
In RKAndroidTool tick the loader before flash.
DevTool.pngImage Enlarger
68
2015/10/14 - 21:15
Repacked build v1.0 with the new tool-set and swapped mounts: http://crewrktablets.arctablet.com/?wpfb_dl=2708
JS79
Forum Posts: 14
69
2015/10/14 - 23:25
Pls find attached the latest loader. Unzip it before flash.
I managed to unlock my tablet with this new loader. 🙂 🙂 🙂
I have already installed all over again and I think everything is working as it should.
Thank you so much for the help given ... 🙂
note: I have used this stock rom from the 2€ tablet provided by the Portuguese DECO, that I have download from here: mega:///#!x4B0RaSS!PrQ5M91dQqvQGhisJlsCdkZbRsY7kRD6qHxtsyWr_sc
pablosuazo
70
2015/10/14 - 23:52
Hi Oma,
I have the same tablet than the user mballes with the kernel 3.10.0
root@frank-desktop#61
Fri Jul 17 19:19:44 CST 2014
I have flashed, following the instructions, the files attached at post #68. Now the tablet is not booting up.
Everything was fine, no errors during the process, but still is not booting.
If I try to flash again, now the AndroidTool only detects the device and shows "Found One LOADER Device" while I keep pressed Vol+ and Power. As soon I stop pressing these buttons, AndroidTool stops deecting the device and shows "No Devices Found"
ALthough I keep pressed the VOl+ and Power buttons to keep the device in the LOADER mode, at some point the "No Devices Found" message appears during the flashing of the system.img step and it stops. It looks like the tablet is able to keep in the LOADER mode only for a seconds before leaving it (besides I keep pressing Vol+ and Power buttons).
Any workaround?
Thank you in advance.
Aron65
Forum Posts: 17
71
2015/10/15 - 07:11
pablosuazo said
Hi Oma,
Any workaround?
I have the same problem!
After about 30 seconds tablet goes out from loader mode and flash fails.
But tablet goes out loader mode after about 30 seconds also if it's not flashing.
mballes
Forum Posts: 22
Thanks Received: 5
72
2015/10/15 - 10:25
Aron65 said
pablosuazo said
Hi Oma,
Any workaround?
traductor - Buscar con Google
Leave hold down power , then you can load
mballes
Forum Posts: 22
Thanks Received: 5
73
2015/10/15 - 11:27
Hello Oma.
Indeed , this rom does not start . I've uploaded with the original. this folder rocdev ok in my tablet.
In addition, the parameters must be missing in the lake, no swap ; the internal sdcard as Unmount.
Aron65
Forum Posts: 17
74
2015/10/15 - 12:55
http://i61.tinypic.com/2yxhfyh.pngImage Enlarger
With the power cord plugged in, I was in loader mode permanently.
I completed the flash, but the tablet does not start!
mballes
Forum Posts: 22
Thanks Received: 5
75
2015/10/15 - 13:03
it does not work. no "found one Adb device. Correct is "Found One LOADER Device" .
pressed Vol+ and Power, or only Power,  no cord plugged in.
65 Guest(s)
Devices in use: Desktop (61), Phone (4)
jacksonrid
usdown
ibob64
kawi
vetBro
