Nameless 2 Euro Promotion Tab Android 4.4.4 [RK3126 and NMC1000]
Latest version of the 2 Euro promotion Tab (originally based on RK3026)
46
2015/10/13 - 17:10
mballes said
i Flash the build from post #20.
You can  swapped mounts, internal-external sd?
as I can resize partitions?
Internal memory is left with only 600 mb .... and I can not get data from some games obb ...
Great! What is the NAND size of the tab?
Anything else noticeable?
I shall do a new build with the latest Flash-Tools and with swapped mounts.
mballes
Forum Posts: 22
Thanks Received: 5
47
2015/10/13 - 19:05
Hello OMA.
 I've seen the partition size is changed, the file with the CMDLINE in parameter.txt  file. thanks.
But as you can not do swap int-ext sd.
my tablet brings a different kernel, is #61 and the build from post #20 dont work the wifi.
Here is the complete DUMP
and here a Folder with single files, but without the system.img (700mb) that is in the dump.
Thank you very much for your help.
forgive my English translator of google
Aron65
Forum Posts: 17
48
2015/10/13 - 19:27
Best is to use Win7. Do not use USB3.0 ports.
Download the test pack from post #28 to the root (C:/) of your PC. Start the included Driver Assistant. Uninstall the driver first, then install.
Flash the firmware from post #20. Open RKAndroidTool with admin rights. Excecute LowerFormat first, then execute Run.
Pls do NOT use RKBatchtool. Especially do not run it at the same time then RKAndroidTool, as it will catch the flash driver.
Thanks!
When I excecute LowerFormat, I have "Match device type failed, stop ranning!"
When I excecute Run, I have Download Boot Fail.
I am in MASKROM mode.
49
2015/10/13 - 19:38
Hm, sounds not good. Use the DevelopTool to flash the loader first.
50
2015/10/13 - 19:46
EIDT: Tab has an other wifi chip. Builds in this thread are for NMC1000 wifi. So couldn't work.
Current WiFi chip is ESP8089.
What is the NAND size of the tab? Do you have a link to the reseller?
Interestingly there are two kernel on this tab:
- kernel #24 preemt 3 Jul 2015 (in boot.img)
- kernel #61 preempt 17 Jul 2015 (in kernel.img and recovery.img)
mballes
Forum Posts: 22
Thanks Received: 5
51
2015/10/13 - 20:58
Still ESP8089 wifi. So should work.
EDIT: do we talking about the same tab? There are two kernel on this tab:
if the tablet is OCU 2 euros rk312x.
as I see the size of the nand?
52
2015/10/13 - 21:06
Pls post a screenshot settings/storage (full size).
mballes
Forum Posts: 22
Thanks Received: 5
53
2015/10/14 - 09:08
Screenshot_2011-04-02-09-43-23.pngImage EnlargerScreenshot_2011-04-02-09-43-33.pngImage EnlargerScreenshot_2011-04-02-09-43-36.pngImage EnlargerScreenshot_2011-04-02-09-43-56.pngImage EnlargerScreenshot_2011-04-02-09-44-04.pngImage EnlargerScreenshot_2011-04-02-09-44-12.pngImage Enlarger
anto87sr
54
2015/10/14 - 11:43
with develop tool I have the same error of JS79: "<Layer 6-3> Download Boot Fail   **********Action Fail**********"
Maybe is the loader RK3188Loader(L)_V1.24.bin not good?
Aron65
Forum Posts: 17
55
2015/10/14 - 12:41
http://i60.tinypic.com/v8ewkj.pngImage Enlarger
Don't work...
56
2015/10/14 - 16:02
Pls find attached the latest loader. Unzip it before flash.
Aron65, JS79
Aron65
Forum Posts: 17
57
2015/10/14 - 16:30
GOOD! Now I can go in loader mode!
But flash stops after a while
http://i60.tinypic.com/rlgz2p.pngImage Enlarger
58
2015/10/14 - 16:32
Did you execute LowerFormat?
mballes
Forum Posts: 22
Thanks Received: 5
59
2015/10/14 - 17:03
Hello. Oma.
I posted the screenshot in the post 53.
Is that what you need?
thanks.
Aron65
Forum Posts: 17
60
2015/10/14 - 17:20
Yes
73 Guest(s)
Devices in use: Desktop (65), Phone (8)
jacksonrid
usdown
ibob64
kawi
vetBro
