Latest Rikomagic MK802 III Mini PC firmware update from http://www.rikomagic.co.uk/forum/viewtopic.php?f=9&t=3193
This firmware comes fully rooted by default, major new features are remote control and Wifi hotspot feature (see documentation included in the archive)
Linux Kernel:Â Linux version 3.0.8+ (ant@test-desktop) (gcc version 4.4.3 (GCC) ) #110 SMP PREEMPT Thu Nov 29 09:45:17 CST 2012
Android build 4.1.1 (Jelly Bean)Â :Â rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/eng.ant.20121129.094717:eng/opinions-on-teclast-p90hdst-keys
Firmware download mirror:Â rikomagic_MK802III_20121129.zip
Changelog:
1. rooted.
2. Added mobile phone remote function,even can play somatic games.
(manual detail pls refer to manual)
3. Added wifi hotspot.(manual detail pls refer to manual)
4. solved some HUB,USB LAN adapter compatibility problems.
Just to clarify, this update comes from the manufacturer, not us Â
We'll eventually build a custom firmware later offering more space for apps and few other enhancements.
I've just posted a custom firmware that offers increased storage space for apps (2 Gb instead of 500 Mb).
See here:Â
Our custom firmware (update.img) needs to be flashed using Rockchip flashing tool.
We should provide a detailed guide for the procedure in a couple of days.
2012/12/07
I have no idea how to install the update.img. I cant get the device to detect in the rockchip flashing tool because cant get it into download mode.
can someone post some pics showing how to prepare the device to connect with the pc.
thanks
2012/09/27
Hello. Recently bought this Android Mini PC.
http://dx.com/p/dual-core-android-4-1-google-tv-player-w-tf-wi-fi-1gb-ram-4gb-rom-black-163836
Can I use roms from other manufacturers like the ones posted in this part of the forum? I mean if they are all RK 3066 based they are essentially the same thing, no?
Also is there a generic rooting method for RK3066 based mini PCs?
Thanks.
Yes and no, there are differences in the Wi-Fi drivers and other drivers, so i don`t recommend flashing a firmware from another device unless you know how to unbrick`it and you are aware of the risks.
psolord
2012/09/27
Well I can accept the responsibility and go ahead but not blindly.
Do you have any tips of how should I proceed. I have some fair experience coming from my U30GT tablets. Is the upgrade procedure similar? Do I use the Rockchip tool for this job?
Also how do I put my Android mini PC to service mode? There is no power nor volume buttons.
If I connect the mini PC to my desktop PC and start up the rockchip tool, can I download the stock firmware so I can flash it back? Will this be sufficient to unbrick it?
In case anyone is interested, I have just posted a new Android 4.2.2 custom firmware update:
70 Guest(s)
Devices in use: Desktop (64), Phone (6)
