CM10.1 test build is here: http://forum.xda-developers.com/showpost.php?p=45622046&postcount=597tYou can try with Pipo U8 kernel: http://crewrktablets.arctablet.com/?wpfb_dl=743
Thanks, I'll wait for more stable, as the tablet is not mine
2013/08/29
I need rooting my Pipo U8 to solve some problems with the touch screen (ghost touchs), but my notebook does not recognize the Pipo U8.
I connect it, and is an exclamation yellow (in manager devices on windows 7), I try to install rockchip drives but windows 7 is not.
Any way to fix this?
I can not install rom on it, because my notebook does not recognize the Pipo U8.
Can anyone help me please?
2013/10/03
I am new to all these flashing things so i am sorry if my questions are stupid or something but i found out that this rom is very good and i want to try it.
1) the 4GB internal storage is optional like i saw in others roms or that's it?
2) do i need all these files too and what are they and how am i gonna use them?
TabletUI fix
PhabletUI fix
Battery Percentage mod
Battery Percentage default
Settings mod
Settings default
3) i saw in the instructions and in a guide video in youtube that because the rom is for chuwi v88 it needs the volume button to go in flash mode and also if i am correct in order to move in the menu when it is in cwm but pipo u8 doesn't have volume button so what's there?
thank you.
los 4 gb es opcional, lo demas no lo se, para ponerlo en modo flash desde RKBatchTool da la opcion de reiniciar a modo flash CREO QUE ES BOTON SWITCH yo lo he probado pero no ha funcionado
pero creo por que instale ayer windows 8.1 y tendre que reinstalar drives
root
https://www.dropbox.com/s/wvc8tvq4cw84moj/RK3188_ROOT.rar
(la tablet en modo depuracion usb activado, acordaros)
ejecutar el Root.bat, hace un reebot e instala el superSU
ya esta
busque en goglee : Rockusb_v3.5 y SAMSUNG_USB_Driver_for_Mobile_Phones_1.4.8.0.exe
y ADB-Drivers instale todo eso y tendria que funcionar, si no lo encuentre, miraria de darselo yo
PERDONEN NO PONERLO EN INGLES, PERO AHORA MISMO NO TENGO TIEMPO, NO VOLVERA A PASAR SORRI
The storage space allocated for applications (/data partition) is determined by the parameter file (located in rockdev directory from Oma firmware package)
If you want different storage space, you need a specific parameter file.
I wanted to answer before taking children to school why not use translator
I think all this is optional, at the moment I use the original rom rooted
usb rock 3.5 adb drivers y usb samsung in zip
https://mega.co.nz/#!k9xTlYJK!CFK3YnulWj_5ZGqVvCTGCRi7Dc59Qm8NzwCmh9diShU
edit, this is new ... with 8.1 windows update does not recognize the tablet
and mk802iii (mini pc) in order anything, this flasher
2013/05/12
I don't know if you've seen that Pipo just released an update for Pipo U8 ( http://www.pipo.cn/En/index.php?m=Product&a=show4&type=2&id=280 )
It is written as an android 4.4
Delicious I'll have a look.
2013/05/12
I quite think that the only difference is the default language and that you can change it easilly. I hope I'm not mistaking.
EDIT: I confirme that you can change the language very easilly. It is even in the first screen when you start the tablet after flashing, so no need to seek the parameter into a mess of chinese characters.
The following users say thank you to theophae for this useful post:
skiper19689Most Users Ever Online: 803
86 Guest(s)
Devices in use: Desktop (77), Phone (9)
cutierogue
hans41
rickybk
