[ ROM ] Pipo U9T (Ultra-U9T) custom root Android 4.4.2 KitKat firmware (2014/05/09)
2014/06/02 - 22:13
Here is an Android 4.4.2 KitKat rooted custom firmware for the PiPO U9T (aka Ultra-U9T) tablet. This firmware is based on the official firmware dated 2014/05/09.
(U9T 4.4 version 20140509.img)
400xNxpipo_m9_pro_android442_kitkat_20131226_kitkat_b.png.pagespeed.ic.OX66oTHP96.jpg
Build information:
Linux Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #643 SMP PREEMPT Fri May 9 10:12:58 CST 2014
Android build: rockchip/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140509.101751:eng/opinions-on-teclast-p90hdst-keys
RK3188Loader(L)_V2.10.bin
  • root with latest SuperSU version 1.99r3 (free version)
  • increased space for applications (/data partition) to 7 GB
  • disabled OTA updates (may cause problems)
  • added Google Experience Launcher (GEL) in addition to iFive stock launcher
  • optional package to fix broken apps (Contacts/People and Calendar sync)
  • included temporary fix for multi-user support, thanks to didierm
  • optional ClockworkMod (CWM) Recovery easy install package
Download: kasty-pipo-u9t-442-20140509-rooted7_mu.zip
Use Rockchip Batch Tool version 1.7 to flash the firmware, use Restore button.
If you like our work, please support us to keep the site alive and contribute to our efforts.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a PiPO U9T to test it.
Thanks Oma7144Wink
Oma7144, otyg
otyg
2014/06/03 - 08:11
kitkat CWM (or ClockworkMod (CWM) Recovery easy install package ) not working on pipo u9t,
I tried using the arctools installer to install it doesn't return an error, but doesn't work.
so I tried to manually flash it from root adb I get this (using the script from arctools installer)
./flash_image recovery recovery.img
and I get
error scanning partitionsfailed with error: -1
partition layout
root@rk3188:/mnt/internal_sd # ls -al /dev/block/platform/emmc/by-name/
lrwxrwxrwx root root 2014-06-02 22:58 backup -> /dev/block/mmcblk0p5
lrwxrwxrwx root root 2014-06-02 22:58 boot -> /dev/block/mmcblk0p3
lrwxrwxrwx root root 2014-06-02 22:58 cache -> /dev/block/mmcblk0p6
lrwxrwxrwx root root 2014-06-02 22:58 kernel -> /dev/block/mmcblk0p2
lrwxrwxrwx root root 2014-06-02 22:58 kpanic -> /dev/block/mmcblk0p9
lrwxrwxrwx root root 2014-06-02 22:58 metadata -> /dev/block/mmcblk0p8
lrwxrwxrwx root root 2014-06-02 22:58 misc -> /dev/block/mmcblk0p1
lrwxrwxrwx root root 2014-06-02 22:58 recovery -> /dev/block/mmcblk0p4
lrwxrwxrwx root root 2014-06-02 22:58 system -> /dev/block/mmcblk0p10
lrwxrwxrwx root root 2014-06-02 22:58 user -> /dev/block/mmcblk0p11
lrwxrwxrwx root root 2014-06-02 22:58 userdata -> /dev/block/mmcblk0p7
using RKAndroid Tool 1.37 to flash reocovery.img 0x00010000 causes the pipo logo then just a black screen on booting recovery .
on a side note the cifs.ko , md4.ko modules cause the tablet to freeze,reboot (probly a kernel panic) when trying to mount a remote share. I have even tried several kernel sources and toolkits to compile the kernel module but all end in the same result a reboot when using the mount command. , the modules will insmod fine though so I'm at a loss what the issue could be.
Don't buy from pipo-store.com.
sanguevivo
2014/06/10 - 00:02
Is it possible To Install an older android versione on pipo u9t? I would to install android 4.2 cause I've problems with calls.
Aliaksandr Maskalchuk
2014/08/06 - 14:38
How to change size space for applications (/data partition) to initial 12 GB and how to see folder androiddata. Tommorow look parameter file in firmware image. Why in parameter type rk3066 and model U8. I download original firmware and see parameter file in original firmware and do changes in moded firmware.
bensou
2014/08/12 - 10:42
Hello, I followed your steps and everything right in the recording of the new ROM.
I find a serious flaw in the ROM. In Standby (display off) mode, the mobiles do not work data (3G). If we display on mobiles working with data (wifi OFF) everything works fine, but when you lock the tablet (Standby) data almost instant (incoming calls when you arrive) are disconnected.
Programs like whasapp, facebook, ... not notified in Standby.
--- If the tablet is connected by wifi, everything works perfectly !!
This problem is also has the original version (4.4.2).
I've tried different App's with and without root to force the mobile data without good results ... I pushed the data (always) in advanced wifi settings, I've tried almost everything.
Is there a file that you can edit a value not to turn off mobile data?
I repeat that the problem only happens with mobile data when the screen turns off.With wifi works perfect!
regards
daye
2014/08/13 - 08:01
hello
for me the pipo U9T is very bad
Bad GPS, all time out
after, big crash with calls and can't phone with bluetooth fonction
Batterie never more 88%
And finaly.... this rom can't install...
so is a tablet phone ou perhaps  a book-press
2014/08/13 - 08:23
daye: "And finaly…. this rom can't install…"
this is rom is update on tablet pc normally, I update without problem!!!! Gps work, but not fine, on three!!!
with this firmware only 7 GB nand flash, but root rights
I get file parametr with official firmware and change this file in this moded firmware and get 12GB nand flash for user data
daye
2014/08/13 - 12:50
i'm await a more stable rom...
Thanks for cookers
2014/08/13 - 13:33
this rom is stable. For GPRS you need add file gps.conf in system directory with root rights. How many days wait yet?
daye
2014/08/13 - 20:12
i'm await A 4.4.4 rom
so, with the 12 gb partition.
Long times without change rom and now i must be a begginner....
128 Guest(s)
Devices in use: Desktop (124), Phone (4)
