[ ROM ] Pipo U8 (Ultra-U8) custom root Android 4.4 KitKat firmware (2013/12/04)
Thanks Received: 3177
2013/12/07 - 16:05
I think I found one possible reason why the root does not work on my custom firmware, I'll build and upload a new one later today.
skiper19689
skiper19689
Forum Posts: 31
2013/12/07 - 22:53
:) I have everything installed again because I gotta make root
but if you go up, the taste, thank you
attempted .... recovery and I've had to reflash :)
so I have the u8 waiting to try the firmware :)
 otherwise, when installing apps ... not the shortcut is created on the primary display
  • increased space for applications (/data partition) to 4 GB??
 would not be better to increase to 10gb, 14g :)
move anything as it leaves the 4.4
alert!!
would be good to put in the first post, which is good for U8
otg because it does not work in recovery mode
just leave and enter buttons: (
GRACIAS!!
skiper19689
Forum Posts: 31
2013/12/10 - 11:36
curios thing I loaded the rom
RileyROM 1.6
and the same thing happened
2013/12/10 - 11:52
skiper19689, to be honest I don't understand much of your tests with our custom firmware, some things probably got lost in translation Confused
Does our firmware (kasty-pipo-u8-44-20131204-rooted4b.zip) flashing works fine, it's just root not working ?
Anyone else has flashed the firmware and could report as well ?
skiper19689
Forum Posts: 31
2013/12/10 - 13:34
everything works ok, only root does not work
I downloaded another rom from another site and same problem, no working root
is that only
CWM: does not work because you can not move menu
OzzyMonkey
2013/12/11 - 09:14
Thanks Op,
Performed a restore installation, pretty happy with ROM generally.
Confirm issue with CWM and touch/mouse not working.
Did some basic test if that helps anyone
https://docs.google.com/spreadsheet/ccc?key=0ApxNGs0kwUGRdFhfZmo0V0FxOW5jdFQ0VDdab2hhd3c&usp=sharing#gid=0
'Challenges\Opportunities' as we call them at work :)
Low settings - wifi on/off cover text in portait mode
Low settings - Bluetooth on/off cover text in portait mode
Medium no root - known issue
Low - :| wireless 'keep wi-fi on during sleep, always doesnt work same issue in 4.2
The following users say thank you to OzzyMonkey for this useful post:
2013/12/11 - 09:29
Thanks for your report OzzyMonkey.
I'm still working to fix the root issue, not that easy without having an actual tablet to test.
clydde
Forum Posts: 21
2013/12/11 - 16:21
New Official Firmware in Pipo home site -  date 2013-12-10 v 4.4.1
Cuestion - I see the chinesse version but no english version firmares in 4.4 Android original, who is the diference?
2013/12/11 - 17:46
tillyv
2013/12/12 - 03:00
Thanks for the ROM. Was able to install it and root my tab through Kingo Root. Problem was after installation, not sure if it messed up the drivers on my PC and I have to reinstall RK drivers. On the tablet side, I tried to restore all my apps and games through Titanium backup but most of my games force closes like Asphalt 8, Fifa 14 and RR3. Currently using 4.2.2 and restored everything back. Hope the new ROM fixes this problem.
egon64
2013/12/19 - 09:05
Do you have maybe some information when we can expect android 4.3 or 4.4 for PIPO M1 PRO tablet ?
Best Regards
egon
plamen_032
2014/05/08 - 13:38
Hi Can I  put this ROM on my Pipo S3 pro? What will be happen?
71 Guest(s)
Devices in use: Desktop (62), Phone (9)
squal
squalangel
anqilan456
havetoregister
werasler
5256makc
