Seems the system is corrupted somehow. Flash the stock firmware: http://www.pipo.cn/index.php?m=About&a=gujian_show&id=185
2014/04/28
I have a Pipo M9 Pro that the system does not enter, forever it is on the screen that appears PIPO name and never leaves, enter the recovery mode by pressing the power and esc buttons and displays a lying android, with a red exclamation and will not appear any command. as I do the command lines appear on this screen ?? Tablet has no physical volume buttons ...
my windows is win 7 64 bit, and does not recognize the tablet in any way! I need to recover this device! help please!
Here is the latest driver assistant: http://crewrktablets.arctablet.com/?wpfb_dl=2398
Uinstall the driver and install again. Then try to start the flash-mode by using the key-combination.
58 Guest(s)
Devices in use: Desktop (46), Phone (12)
cutierogue
