IMPROVING THE GPS FIX on RK3XXX devices.
The installation through ADB of the fix to get better gps fix.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2013/12/21 - 18:18
Preparation :
A rooted ROM or (but this is for only  for Kasty PipO M9pro #407. 20140504 version) bcoz it contains the build.prop  for this version and device. If you are and advanced user you can change the "build.prop" inside this versionwith your device version.
1.The "gps.conf" file with the following statement in it :
Contains reference to "asia.ntp servers, europe.ntp servers and north america only ntp servers.
2.This will install NTPSync app that is most important for GPS accuracy. It syncs with your country's  ntp time servers
3.  NULL and VOID
4. Copy the zip files onto sdcard and go into CWM >>>select INSTALL>>(this zip file)
5 NUL and VOID
6. When restarted go to NTPSync >> select "NTP server" option and enter your country code.  e.g "de" for Germany, "fr" for France, "in" for India, "cn" for China.
CHANGELOGS:
Install only through CWM/TWRP therefore DO NOT UNZIP THE FILE
Installs GPSTest and NTPSync
Install QuickExit to quickly exit a non responding applications without waiting or rebooting it will always auto restart.
 DONT USE THE PREVIOUS VERSION, USE THIS LATEST VERSION that instals through CWM/ TWRP
todguy
Forum Posts: 11
2013/12/30 - 15:18
Does the tablet need to be in recovery mode before you do this?
cracktech
Malaysia
Forum Posts: 432
2013/12/30 - 22:59
No need just make sure that it has USB debugging  to "ON" and connect the PC and device (wait for the USB device and USB debugging on the PC and device to be connected, ensure that all USB drivers are available)   and just run the "**.bat" file and it will do the rest. If you are wiser yu can use this to manually "ROOT"a stock firmware by adding the appropriate file with the appropriate "chmod/chown"  permission statement (I took this from the ROOTING script.)
Sorry bout the late reply been busy on other forums too. If you are living in the US you can request from me  another suitable script specifically for the USA from the rest of the world all you have to do is to change the gps.conf file to your appropriate country.Remember to to rename the file "gps.conf(xyz123)" to just "gps.conf"
After it has finished it will reboot the device.
Goto : http://www.arctablet.com/blog/forum/pipo-tablets/improving-the-gps-fix-on-rk3xxx-devices/#p35207
pipotablet
lew247
2014/01/19 - 14:36
Could you be so kind as to tell me where to get the proper ADB windows drivers for the M9 please?
No matter what I try I cannot get your script working on windows 8
I even used the Windows 7 laptop that I use for flashing roms and tried to change the drivers but none are working
I wonder if its as a result of using Finless 1.5 rom and the computer picking it up as an I9300
I did try restoring the original build.prop instead of the one supplied so the play store works properly but I cannot find the proper drivers anywhere
I even tried installing Moborobo to install the drivers but nothing works
The following users say thank you to lew247 for this useful post:
Andi_Berlin
cracktech
Malaysia
Forum Posts: 432
2014/01/19 - 19:10
Try this : https://mega.co.nz/#!XlAHXDyC!Qr6y0lhd2rpSAdU0rk-CSmrc36Bjjju4hvFkSEMM_08
or the RK Driver installer for Win7/Win8 (not Win8.1) : http://www.mediafire.com/download/sd9h9dckq10wz09/RK-Release_DriverAssiStant.zip
Or in case of emergency plaese use the universally recommended ADB driver PDA Net (attached below)
Please delete the "build.prop" file inside the folder or just add the sysmbol "##" to the front of "build.prop" file as the build.prop is meant for Max M9Pro with a different version and screen resolution, or else you might end up with a non booting M9 (this build.prop is meant for M9Pro only) Please omit the "build.prop" from being installed into M9 this is meant for M9pro.
lew247
2014/01/20 - 08:54
The 2nd driver worked beautifully on windows 8.1 X64 all I did was go into the properties and choose compatability as Windows 8 and it installed and worked perfectly
cracktech
Malaysia
Forum Posts: 432
2014/01/20 - 09:42
Good for you!
You shall be the last support that I will provide on any matter on this Forum. I will NO LONGER ACTIVELY PARTICIPATE on any matter in this Forum except as an observer , (waiting for March '14 when RK factory will release the actual KiTKat kernel not the current 3.026 kernel).
please go to this link for the latest update dont use any previous versions: http://www.arctablet.com/blog/forum/pipo-tablets/improving-the-gps-fix-on-rk3xxx-devices/#p35207
garbuya
Forum Posts: 11
2015/01/09 - 00:57
Can I run in for kasty-pipo-m9_pro-442-20140504-rooted7_mu?
Or it needs some modifications?
cracktech
Malaysia
Forum Posts: 432
2015/01/09 - 17:29
This is actually a general settings fix for GPS settings , it doesnt solve the problems of poor hardware (like M9Pro it has a metal back cover that hinders a good GPS receptions but every little bit of helps count)
Discard the old files  and use this version only for M9Pro #407 20140504 , since this mod contains the "build.prop" to M9Pro only. (If an advance user you can substitute the buid.prop with your device (any) build.prop) but try to leave evrything else intact for effective settings.
Copy this zip file (DO NOT UNZIP IT) and use CWM to INSTALL. In the NTPSync  app you only need to enter your country code in option "NTP server" example : fr.pool.ntp.org (France.)  de.pool.ntp.org (Germany) you only key in 2 letters and set the settings to update daily.
If you find that a lot of time out to connect to ntp (slow sync with servers)servers to your coutry substitute that with your continent i.e. "europe","asia""north-america", "us"
malfrat
Canada
2015/05/04 - 18:54
on a fresh kasty-pipo-m9_pro-442-20140504-rooted7_mu i follow instruction carefully with the oma recovery flashed the update2.zip. now i got android.process.media , play store error flooding no recess after reboot. i try to wipe data/factory reset/pin reset, reload the original recovery but same error. if i try to go to setting/app the device hot reboot alone. all working fine before the cwm and update2.zip flash process. Any advice ? from now i'll flash again the kasty-pipo-m9_pro-442-20140504-rooted7 to at least get a working device...
some help would be nice thx
cracktech
Malaysia
Forum Posts: 432
2015/05/04 - 22:12
I give you this download link : https://mega.co.nz/#!LFsxXIRZ!CjO8oT7ustBGlGwBy-pbcCCAbr6ZyrW8yDHi-G7_73E for your request. Unzip only this file get the update.zip file inside. The size is about 70Mb but that is due to me being lazy in writing an elegant script for symlinking busybox so the bloated size is the full "/xbin" folder content. The actual update is less than 25Mb. Sorry about that.
First use Kannan Recovery Flasher (included) to flash TWRPrecovery (incl.). I am an advocate of TWRP Recovery rather than CWM and almost all of my firmware mods have TWRP rather than CWM.
Then install the zip file inside (DO NOT UNZIP !) It will install SuperSU2.49 and correct the original rooting file where the busybox is installed in "/bin" folder whereas majority of root would expect to find "busybox" in the "/xbin" folder (this will correct it.)
It will install GPSTest Pro for testing satellite signal/ NTPSync where it will sync time to your nearest NTPServer (in your case I have set it to Canada/north-america) this is important to sync your device time and satellite time.
malfrat
Canada
2015/05/05 - 00:12
i found where is the problem... i also try to flash the first post update.zip package but using ManuPc recovery this time and ... same result: sdcard, external_sd and data partition not remount at reboot after the update.zip applied.
i try many way to adb shell some remount command with no success...
it is why all system app that doesn't have depency on /data work fine and system load almost by luck 🙂 and why example my 'root explorer' app won't work like all other user apps....
i'll try that solution https://mega.co.nz/#!LFsxXIRZ!CjO8oT7ustBGlGwBy-pbcCCAbr6ZyrW8yDHi-G7_73E
maybe i would have to flash whole fresh kasty rom again before this update ....?.... due that for now i can't access any partition (sdcard and external) i'll try a workaround to adb push update.zip to system and flash the provided M9ProTWRP_recovery using flash tool 1.37 than reboot to recovery from there and flash the update.zip right from system 🙂 not sure...
Really thx for your hard work on this forum and providing a fast solution to me
(sorry my bad english cuz i'm french canadian speaker)
malfrat
Canada
2015/05/05 - 02:16
error flashing zip
E:error executing updater binary in zip
twrp is perfectly installed via provided apk but update script seem to fail...
(I'm on a fresh install kasty-pipo-m9_pro-442-20140504-rooted7)
cracktech
Malaysia
Forum Posts: 432
2015/05/06 - 08:00
CryMy apologies about the error! I had to use another device to generate the GPS update zip  file. This time with a smaller xbin file (it will symlink on the device itself) so the file have shrunk to 8Mb only.If it doesnt symlink download Busybox installer(Stericson NOT JRummy) and get it to symlink . DO NOT UNZIP the GPS update.zip just straight away INSTALL using TWRP , I had tested it on my own M9Pro.WinkWink
malfrat
Canada
2015/05/07 - 05:21
I reflash the 06-09-2013 jb pro 3g rom as when i get my tab the first time when gps was working...
Can you please do me a favor to do a jb flashable .zip too ? Would be very nice, to be true i'm not so impress about kitkat in some situation... But i'm a flashaolic:-)  i'll be back on kitkat tonight to test that fix and be back once done....
I really appreciate th provided support to user
My english is crappy? You think that i'm a kind of freak or even drunk dead? No i'm french canadian that doesn't use google traslation services:-)
95 Guest(s)
Devices in use: Desktop (83), Phone (12)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
