Build: http://crewrktablets.arctablet.com/?p=3591
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1253
Model fix: http://crewrktablets.arctablet.com/?wpfb_dl=2358
Download pack v1.2. Change kernel in folder rockdev/Images and flash incl. eraseIDB. After first boot into CWM do a factory reset and install the model fix (copy on external sdcard before start).
2014/12/27
This build is for rk3188. Kernel correct this for 3066?
Sry for my eng.
PS. How look parameter here? I need setup it for 8GB or can use that from first link (for 8GB)?
Yes, rk31 builds will run on rk30boards having a 3.0.36+ kernel. Make sure you do NOT flash the loader!
Unzip this parameter file http://crewrktablets.arctablet.com/?wpfb_dl=1804 and copy it into folder rockdev.
No, do NOT flash or touch the loader otherwise. CWM is included. Just flash as advised.
Its already included in the model fix.
2014/12/27
Big thanks for help. It's work. Now need to test it. Stability and ohters function. One more time thanks (before this i test only own modded 4.1 and 4.2 stock on rk30xx).
Ok. I back. Need to ask. What is with video playing? 4k don't show any image when playing, mx player don't work (damage files or something wrong with android)?
Ok, one step back. Flash the build without the model fix. Instead of the 160dpi fix.
Yes, clean install and instead of the model fix the 160dpi fix.
58 Guest(s)
Devices in use: Desktop (52), Phone (6)
