[ ROM ] Sumvision Cyclone Voyager 7" (Pipo S1 compatible) rooted Android 4.2.2 firmware (release 2013/07/09)
2013/08/06 - 20:34
Here is an Android 4.2.2 Jelly Bean rooted firmware for the Sumvision Cyclone Voyager 7" tablet, it is based on the official firmware update from Sumvision.
This custom firmware should be compatible with the PIPO S1 (DS733) tablet.
Build information:
Kernel: Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.4.3 (GCC) ) #24 SMP PREEMPT Tue Jul 9 20:24:52 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20130705.123608:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.51 (free version)
  • increased space for applications (/data partition) to 2 GB
Download: kasty-sumvision_cyclone_voyager_7-422-20130709-rooted0.zip
Flash with Rockchip Batch tool, use Restore button.
djcristi2001, aldohe, class66, daveady, andreab82, anonymousone, fratello, choppertriker
djcristi2001
Forum Posts: 19
2013/08/07 - 09:41
thanks i will try this .... the hdmi not worked before i will see now...
class66
2013/08/08 - 22:13
Thanks for this m8
Have you got any pictures of it working.
Does it have gps enabled
when i had jb 4.1.1 gps worked updated to 4.2.2 from sumvision website and gps does not work
aldohe
2013/08/09 - 04:06
working fine at the moment, no lags whatsoever, playstore working fine
djcristi2001
Forum Posts: 19
2013/08/09 - 13:40
GPS - THE TABLET PIPO S1 DOESNT HAS GPS.....
class66
2013/08/09 - 20:46
@[admin]
title says
i want to use this on my cyclone voyager which has gps does this firmware initialize the gps module.
or can it be made to.
thanks in advance
marc.knuckle
2013/11/10 - 09:58
hey guys.
i have the voyager 7 s/n SUMCV130103368.
i saw that they had released the 4.2 update and wanted to install it.  partly as there is still a volume bug in their 1.4b update i installed a while back.
i realise that it isnt a 4.0 pcb device but i presumed that as the update said okay with pcb 3.0 and 4.0 devices that mine must be a 3.0 and i installed.
now, it boots about 1 out of every 2 attempts, the non boots the wording for either sumvision or the next screen with android on it goes fuzzy and it stays on there.  on the last time i booted successfully, i tried to install an app and it did the same fuzzy writing freeze.
am i doing something worng with the install and would this rom above be okay for me to try a new flash with?
thanks guys.
choppertriker
2013/12/15 - 15:41
thanks for this rom ... nice
2014/02/04 - 10:18
133 Guest(s)
Devices in use: Desktop (126), Phone (7)
spiik
nikitamaan
VMILCINOV
