2016/09/04
PIPO Smart S3 7" RK3066 4.1.1 Can anyone help custom rom for updated android version please
Build is here: http://crewrktablets.arctablet.com/?p=1913
Just change the S3 kernel and install the wifi fix in CWM.
Instructions given in the blog:
decompress with 7zip (change kernel in folder rockdev/Image)
copy format_NAND_fix (and other fixes) to sd-card
boot tab into flash mode
run RKAndroidTool as admin: EraseIDB, Run
first boot into CWM: install format_NAND_fix (and other fixes) from sd-card
reboot, wait 4 min
Kernel and wifi fix are linked under confirmed installations.
The tab is not in flash-modus. In the flash-pack is an instructions.txt included.
MSC device means it is not in flash-(loader) modus. Try again. Maybe also Power and Reset works for you.
2016/09/04
Hi
I restored the PIPO image via RK batchtool 1.8
tried again when ROCKCHIP icon appear junder windows this is indiaction that driver is present
replace the PIPO kernel from
http://crewrktablets.arctablet.com/?p=1913Â in rdev/image folder
again it stuck at CWM recovery when I
8. Wipe data/factory reset
9. Reboot
This is not getting out of CWM loop
ultimateley I have to restore PIPO back to the old firmware
Can anyone help
Currently Online: MINIX2021
111 Guest(s)
Devices in use: Desktop (94), Phone (18)
beelink
TheMentor
smalec
marek.test@gmail.com
MINIX2021
extendedtn
