Touch works fine.
2014/04/12
hi
thank you for the custom roms!
i found a bug in the kk rom (gen 2),
1. When I change the system language to Hebrew (עברית) and restart the device, after the device has rebooted it immediately writes this message "sorry com.android.systemui stoped" and if i change back to English language it worked.
2.And another thing when I try to install  in this device a Certificate (on kk rom)  the installer forced closed
 Any ideas how to fix this bugs?
i am now on JB rom (gen 2) I wanted to know is there a way to Swap the Internal Memory and External SD Card   (other words,  that the device will detect the external card as the Internal Memory of the device and the Internal Memory as the external memory card)? And if there is a way, how to do it?
thank you very much
2014/03/14
Enyoing the tab at the moment ... I did a 2nd gen loader KitKat build– stock 4.4.0 recovery, CWM 6.0.3.1 recovery
– system ext4
– kernel alex #448 preempt 06.05.2014
– internal storage 2 GB
– PhabletUI & Multi-User
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova LauncherÂ
Gen2 loader firmware will frequently generate trouble for the user. So, please read
the instructions carefully to understand how to change between gen1 (v1.24 loader)
and gen2 (v2.10 loader) firmware and vice versa.Hints:
- to improve UI feeling disable all animation scales in developer options
- to improve battery drain set keep wi-fi on during sleep to never
- to get full access to the build enable /system rw in File Manager HD
- to disable su notifications change notification in su app
- to prettify the build use Xposed Framework > Starter PackÂ
– Oma -
Hi friend,
Long time ago since I last wrote, the tablet is constantly turned off, and I got tired Was a while in the drawer .... I have now decided to use it again and I've seen new versions of rom (as always continuing strong job), I installed the latest version of KK, but I see that is not an option to extend the internal space as had the others, there is only 2GB, is there any way? Are the methods of the previous version of kk work? Any recommendations on which leave rom installed? Thank you very much for everything.
Regards, Salva.
I use the v2.0 build. The creepy symlinking of an unified internal storage could make some problems after longer usage. So, I prefer the classic set-up of an app partition and an internal sdcard.
BuhaPer aspera ad astra, we rock the Tablets !
2014/05/05
Hi, I bought two Pipo S6 in February for my kids. One of them died first minutes. Realized later that disconnecting and connecting the battery will fix it, but it happens again now and then.
Early May I updated the FW to the latest on Pipo website (20140428 I think) and they have both worked fine since then.
The last couple of weeks however, I need to disconnect the battery on one of them almost every day, while the other one is doing better.
Do you all have the same problem? Is there anything you can do to permanently fix this issue? Will Oma's ROM fix it?
Regards,
2014/06/28
richardax said Hi, I bought two Pipo S6 in February for my kids. One of them died first minutes. Realized later that disconnecting and connecting the battery will fix it, but it happens again now and then.
Regards,
I have this problem at ALL FW ( Oma and stok pipo), please help me, I'm tired
This is a hardware problem. Make use of your warranty.
2014/02/19
unfortunately,mobile data has stopped how to fix?mobile internet not working.help OMA,please
– system ext4
– ethernet support
– init.d support
– USB-Hub enabled
– Nova Launcher
2014/02/19
download Kingo android root program http://www.kingoapp.com/android-root/download.htm copy-paste link  ,then connect tablet and press root or  another program one cllick root http://www.oneclickroot.com/
Currently Online: dfrt
59 Guest(s)
Devices in use: Desktop (52), Phone (8)
dfrt
PQNY
chema1971
speedyftp
georgicaa97
kkn
