[ROM] Pipo S6 root custom firmware by Oma rocks !
Some stuff around Pipo S6
jjorgr
91
2014/05/08 - 19:15
The following users say thank you to jjorgr for this useful post:
arunas uk
Forum Posts: 11
92
2014/05/10 - 01:14
how to update?procedure?thanks
93
2014/05/17 - 18:52
jjorgr said
New Pipo S6 firmware(20140506)
Be careful, this is a gen2 loader firmware.
jjorgr
94
2014/05/17 - 20:29
No problems so far.... And it's  a very big improvement ,running  very smooth.
Thanks for the warning .
95
2014/05/18 - 21:33
Here is a build based on that gen2 loader firmware
S6 by Oma JB build v2.0
– stock 4.2.01 recovery, CWM 6.0.3.1 recovery
– system ext4
– kernel alex #448 preempt 06.05.2014
– internal storage 2,5 GB
PhabletUI & Multi-User & Multi-Window
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Dateimanager HD (Root)
– Nova Launcher
Gen2 loader firmware will frequently generate trouble for the user. So, please read
the instructions carefully to understand how to change between gen1 (v1.24 loader)
and gen2 (v2.10 loader) firmware and vice versa.
Hints:
- to improve UI feeling disable all animation scales in developer options
- to improve battery drain set keep wi-fi on during sleep to never
- load kernel modules > enable init.d ON in Pimp my Rom (load from Play-Store)
- to get full access to the build enable /system rw in File Manager HD
- to disable su notifications change notification in su app
- to prettify the build use
Xposed Framework > Starter Pack
– Oma -
v2.0_01.pngImage Enlargerv2.0_02.pngImage Enlargerv2.0_03.pngImage Enlargerv2.0_04.pngImage Enlargerv2.0_05.jpgImage Enlarger
96
2014/05/19 - 17:54
Enyoing the tab at the moment ... I did a 2nd gen loader KitKat build
S6 by Oma KK build v2.0
– system ext4
– internal storage 2 GB
– ethernet support
– init.d support
– USB-Hub enabled
– Nova Launcher
Hints:
– Oma -
v2.0_02-1.pngImage Enlargerv2.0_04-1.pngImage Enlargerv2.0_03-1.pngImage Enlargerv2.0_01a.pngImage Enlargerv2.0_08.pngImage Enlargerv2.0_06_art.pngImage Enlargerv2.0_09.pngImage Enlargerv2.0_10.pngImage Enlargerv2.0_11.pngImage Enlarger
pleoss
jjorgr
97
2014/05/20 - 23:19
– system ext4
– ethernet support
– init.d support
– USB-Hub enabled
– Nova Launcher
Hints:
– Oma -
Trying to install the 4.4 2.0 brick my tablet.
When i pressed Vol + and Power made it go dead(beside the red charging led everything went completely dead).
Disconnected the battery >Windows find it>RKAndroidTool find it>flash successful(tried different firmware stock and custom) The flash tool shows process successful but the screen is dead>dosent boot.
Any ideas?
Thanks.
PS.I was coming from the stock 20140506.
SOLVED....My mistake(accidentally disconnected the digitizer)
98
2014/05/22 - 22:33
Still help needed here?
nissy
99
2014/05/23 - 17:01
helo oma
Does this build S6 by Oma KK build v2.0 has  multi-window?
If not, it is possible to install?
100
2014/05/23 - 18:24
No, Rockchip do not provide KK code for multi-windows.
However, there are some Xposed modules which will add multi-windows support.
nissy
jjorgr
101
2014/05/23 - 20:18
No,Thanks.
Accidentally disconnected the screen plug....But it would be advisable to press Volume up and Reset instead of Volume up and Power.
The only bug that i found in both JB 2.0 and KK 2.0 is the stock launcher kicking in from time to time in JB(constant in KK).
....And why didn't you include the Prime Nova Launcher?
I had to nag the chinese 3 weeks for this new firmware...It was worth it.Stock and customs running smooth.
nissy
102
2014/05/27 - 10:31
Can anyone make a custom Rom  that will change the speed of the cpu from 1.4 MHz to 1.6 MHz?
103
2014/05/27 - 14:59
Maybe jjorgr can nag for the kernel sources ... then we are able to compile an oc kernel.
jjorgr
104
2014/05/27 - 15:15
Those days  are long over....Of course,I don't  mind if you carry on my nagging legacy.
nissy
105
2014/05/31 - 22:40
Hello
I thought about buying a tablet pipo s6
I just wanted to make sure that after updating the kernel to #448 is the touch screen problem solved completely?
The touch screen now is 100% responsive?
thank you
Currently Online: 5256makc
115 Guest(s)
Devices in use: Desktop (111), Phone (5)
5256makc
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
