[ROM] Pipo S6 root custom firmware by Oma rocks !
Some stuff around Pipo S6
pleoss
Forum Posts: 15
61
2014/03/30 - 04:22
Yes, but with version 1.1 this problem did not happen, I could work perfectly with the tablet without external sd card, do you know that are exchanged and how can you fix this error? is that it is solved, the external sd memory, which now corresponds to nand flash, is no obligation and I used to have external sd memory, I do not quite understand this working :-( greetings
The mounts are swapped. So, without external sd the build will not run.
62
2014/03/30 - 11:00
8 GB NAND is a bit less, so we need the external sdcard.
To make is easier the following numbers are rounded.
8 GB minus 1,5 GB system = 6,5 GB NAND available
stock: 6,5 GB = 1 GB internal storage (app space) + 5,5 GB NAND flash (internal sdcard)
This will give us the following issues:
- 1 GB app space has to be devided by number of users (multi-user)
- 1 GB app space is full with a few big apps per user
- 5,5 GB internal sdcard is full with 2 videos and 2 app game data (like Asphalt 8, Thor etc.)
v1.2 : 6,5 GB + 32 GB ext sdcard = 4 GB int storage (app space) + 32 GB NAND flash (int sdcard) + 2,5 GB ext sdcard
Advantages:
- 4 GB for 2 user means 2 GB per user
- 32 GB int sdcard is plenty of space for media contents and game data
- 2,5 GB ext sdcard is good for everything you like
v1.2_04.pngImage Enlargerv1.2_04a.pngImage Enlarger
pleoss
pleoss
Forum Posts: 15
63
2014/03/30 - 11:12
Is perfect storage system, I will buy a 32gb SD now. Thank you very much for the great work you do is very good, I'm a computer programmer, but does not work with Android, but I am very interested and want to learn soon.
64
2014/04/02 - 22:06
Pipo released a new firmware which does not boot. The framework crashes the build.
However, the new kernel gives me are far better touch response ;-)
Kernel alex #441: http://crewrktablets.arctablet.com/?wpfb_dl=1661
You can flash it separately with RKAndroidTool. Just tick parameter and kernel.
v1.2_kernel-441.pngImage Enlarger
pleoss
pleoss
Forum Posts: 15
65
2014/04/02 - 22:22
Hi, thank you very much I will try, I have to press EraseIDB and Run?
66
2014/04/02 - 22:37
Only Run. EraseIDB will wipe the partition layout of the NAND.
pleoss
jjorgr
67
2014/04/07 - 01:24
S6_1.0.3-update # 441_20140402 works just fine!
68
2014/04/07 - 16:19
Thank you for joining to let us know.
I believe that. However, the update.img does not boot here on my S6.
Could be that the provided update.img is somehow corrupt. Better would be to provide downloads as a zip file.
jjorgr
69
2014/04/07 - 19:23
I got it from the Pipo site> http://www.pipo.cn/En/index.php?m=Product&a=show4&type=2&id=316 and flashed with the RKBatchTool v1.6
Where did you get it from?
It's nice that your taking the time to work on the S6....The S6_1.0.3-update # 441_20140402 is quite smooth,good working material.
70
2014/04/07 - 19:38
Well, 67 downloads ... 3 are from me.
Anyway, the build is not so interessting. Kernel #441 is the big deal.
jjorgr
71
2014/04/07 - 19:49
I was just saying.....
Rooted+Nova launcher> I get 18400-1880+ in Antutu.
jjorgr
72
2014/04/07 - 20:57
  Just rememberd,you have to go back to stock recovery to flash(the img is fine).Just dosen't work whit CWM.
pilone
73
2014/04/29 - 18:21
i need help with the roms of this tablet Pipo s6.
In my job, we need connect an uvc camera on this tablet but when i plugg the camera usb, the program said driver uvc not found.
I try change custom kernel rk3188 with this options:
CONFIG_VIDEO_DEV=y
CONFIG_VIDEO_V4L2_COMMON=y
CONFIG_VIDEO_MEDIA=y
CONFIG_USB_VIDEO_CLASS=y
CONFIG_V4L_USB_DRIVERS=y
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y<br />
but, when i upgrade the kernel, the tablet dont turn on.
Anybody can help me for get a rom with this options enabled in the kernel for this tablet??
Help please!
jjorgr
74
2014/04/29 - 22:26
pilone said
CONFIG_VIDEO_DEV=y<br />
CONFIG_VIDEO_V4L2_COMMON=y<br />
CONFIG_VIDEO_MEDIA=y<br />
CONFIG_USB_VIDEO_CLASS=y<br />
CONFIG_V4L_USB_DRIVERS=y<br />
Help please!
I keep watching for a firmware update from Pipo ....but I haven't seen one for a while.
Lately it seems that if you contact Pipo customer support by email, they can provide you with a firmware update to deal with a specific problem.
I have been asking about a new firmware on the Pipo Facebook Page(the FB page matters to them.They use it to advertise and do not want bad comments)....but I am only one.Maybe if more wrote they will speed things up.
https://www.facebook.com/pipocn?fref=ts
75
2014/04/30 - 22:37
Maybe we can do a kernel module for the cam. What is the USB ID? You can read it with the app USB Host Controller.
http://www.ideasonboard.org/uvc/#devices
53 Guest(s)
Devices in use: Desktop (51), Phone (2)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
