[ROM] Pipo S6 root custom firmware by Oma rocks !
Some stuff around Pipo S6
46
2014/03/27 - 22:54
Download again and try: http://crewrktablets.arctablet.com/?wpfb_dl=1644
pleoss
pleoss
Forum Posts: 15
47
2014/03/27 - 23:10
Hi, I now have Google Play, but does not work google+ :-(  thanks.
arunas uk
Forum Posts: 11
48
2014/03/27 - 23:12
oma how to do nand rom memory 8gb,from 2.3gb again to 8gb?.it was 8gb,when i bought new s6,then i did nand flash format.with oma.JB ver.3.0
49
2014/03/28 - 07:23
We are talking about which build? Are you limited on partition size by doing something?
50
2014/03/28 - 07:25
Gms-core should ask for an update.
pleoss
pleoss
Forum Posts: 15
51
2014/03/28 - 12:03
Oma,I did not ask for any update :-( Thanks.
52
2014/03/28 - 22:16
I gave up to control the gms-core missmatch in an unknown userdata environment.
Here is a fairly new build based on latetst stock rom 20140228: http://crewrktablets.arctablet.com/?wpfb_dl=1647 & format_NAND
v1.2_02.pngImage Enlargerv1.2_03.pngImage Enlarger
pleoss
pleoss
Forum Posts: 15
53
2014/03/28 - 23:02
Thank you very much, is there any way to change the rom without losing everything I have?
pleoss
Forum Posts: 15
54
2014/03/28 - 23:37
Hi friend, no problem to lose all that I have. I'm thinking of trying the kitkat, is it stable? Do you have any problem this rom? thanks.
55
2014/03/29 - 09:17
No, the problem is userdata. So we need fresh installation.
KitKat is stable, of course.
pleoss
pleoss
Forum Posts: 15
56
2014/03/29 - 09:57
Hi, very good job with Kitkat my friend. I really like their fluency, but I've had trouble with the locality in all applications (1water and map, for example), also problem with multi user. I'm back to Jb V1.2 and now everything perfect. Thank you very much for everything.
pleoss
Forum Posts: 15
57
2014/03/29 - 15:10
Hi Oma, I have a problem with V1.2, I have no external SD card and NAND flash tells me I do not have and can not download anything and can not have photo, an alert is telling me I do not have SD card installed
58
2014/03/29 - 15:12
You need to install the format_NAND via CWM.
pleoss
Forum Posts: 15
59
2014/03/29 - 15:30
I have installed it, but this is the aspect of my storage without putting external SD
IMG_20140329_152924.JPGImage Enlarger
60
2014/03/29 - 18:54
The mounts are swapped. So, without external sd the build will not run.
pleoss
52 Guest(s)
Devices in use: Desktop (50), Phone (2)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
