[ROM] Pipo S6 root custom firmware by Oma rocks !
Some stuff around Pipo S6
31
2014/03/23 - 07:31
What have you done?
verbenchick
verbenchick
32
2014/03/23 - 07:44
I emptied the plate to 2%. put the charger is switched off and is no longer included! I charged it all night! I think it's a failure in the software Android 4.2!
verbenchick
33
2014/03/23 - 07:47
Bought it yesterday! I do not have time to transport the film off! May need to do a hard reset?
verbenchick
34
2014/03/23 - 07:48
But I do not know how!
verbenchick
35
2014/03/23 - 08:38
Oma please help me!
pleoss
Forum Posts: 15
36
2014/03/23 - 09:04
I have read that there is a bug with the load, if the tablet is not completely unloaded restarts, but I can not help to solve the problem, not as it is. Maybe opening the tablet and off and connecting the battery. A greeting.
The following users say thank you to pleoss for this useful post:
verbenchick
37
2014/03/23 - 09:44
So the tab is not booting? What do you see: kernel logo, battery animation?
verbenchick
verbenchick
38
2014/03/23 - 10:21
Nothing, black screen! If i go to stock recovery! But I do not know how! is dead!
39
2014/03/23 - 10:32
Ok, the tab is deeply discharged and the kernel won't boot anymore (which is normaly a security feature of the kernel, but for tabs without charger a heavy bug ...)
We need to start the tab from flash-modus.
Here is the stock firmware: http://crewrktablets.arctablet.com/?wpfb_dl=1390
Instructions are included. Leave point 2 out.
verbenchick
verbenchick
40
2014/03/23 - 10:58
You do not have instructions! By which I can enter in stock recovery Pipo smart s6?
41
2014/03/23 - 11:09
This doesn't help. Stock recovery is only good to format user partitons. You cannot enter it.
verbenchick
verbenchick
42
2014/03/23 - 11:29
I've read that if loaded as though something! I will be able to try a little charge! Unless of course charging case!
pleoss
Forum Posts: 15
43
2014/03/27 - 13:39
Hi Oma7144,
First thank you for your work. I have had the problem of brick, but I'm open tablet, switched off and the battery and it worked, then I installed your version 1.1 and everything is perfect, I only have one problem and that is that the Google+ app does not work, always says has not been able to connect, you know what could be the problem?
On the other hand I'll be back to ask if anyone has found any wildlife support our tablet.
A greeting and thank you very much, Salva.
44
2014/03/27 - 21:58
This is most likely a conflict with gms-core.
Pls install this fix:  http://crewrktablets.arctablet.com/?wpfb_dl=1644
You will have some force closes of gms-core until the latest Play-Store has been loaded again in the background.
v1.1_04-4.pngImage Enlarger
pleoss
pleoss
Forum Posts: 15
45
2014/03/27 - 22:26
Hello I installed the fix, but it has disappeared app google play, what do I do? Thanks
50 Guest(s)
Devices in use: Desktop (48), Phone (2)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
