Recently bought a Pipo S6 @ geekbuying for 100 EUR presell. Shipping time to Frankfurt was 5 days.
Everything is fine. Well done geekbuying!Â
Tab is not yet on the Pipo product page ... my tabs serial number is #40
(I) Stock JB 4.2.2 multi-window rooted
(II) Oma JB 4.2.2 multi-window v1.0 & format_NAND
- CWM 6.0.3.1 recovery
- system ext4
- latest kernel #403
- internal storage 4,0 GB
- device spoofed as Nexus 7
- PhabletUI & Multi-User & Multi-Window
- battery percentage mod
- ethernet support
- init.d support
- gameloft compatible
- USB-Hub enabled
- gamepad compatible (PS2, XBox, ...)
- kernel modules (cifs, tun, lan, serial, audio)
- latest hosts, su, su-binary, busybox
- Reboot Menue, Pimp my Rom, FX Sound
- Dateimanager HD (Root)
- Nova Launcher
admin, pleossPer aspera ad astra, we rock the Tablets !
(III) CM10.1 build: http://crewrktablets.arctablet.com/?p=1950
Kernel: http://crewrktablets.arctablet.com/?wpfb_dl=1396
Modell Fix: http://crewrktablets.arctablet.com/?wpfb_dl=1394
(IV) KitKat test build: http://crewrktablets.arctablet.com/?wpfb_dl=1412
Build will run on 1st generation loader and without the other creepy stuff of the already seen KitKat stock roms.
It was necessary to build the complete wifi system for the MT5931 chip. Bluetooth is not working so far.
- stock & CWM 6.0.3.1 recovery
- system ext4
- ethernet support
- init.d support
- USB-Hub enabled
- Nova Launcher
bluetooth fix - http://crewrktablets.arctablet.com/?wpfb_dl=1416
Please report any issue back.
Could be. More likely is the hardware runs more stable. We have seen kernel related max 1,4 GHz already for Vido Mini and some Chuwi V88 population is instable @ max 1,6 GHz.
However, you will not see any difference in normal usage. Overall benchmark is about 10% less @ max 1,4 GHz.
Which build?
2014/02/19
– system ext4
– latest kernel #403
– internal storage 4,0 GB
– device spoofed as Nexus 7
– PhabletUI & Multi-User & Multi-Window
– battery percentage mod
– ethernet support
– init.d support
– gameloft compatible
– USB-Hub enabled
– Reboot Menue, Pimp my Rom, FX Sound
– Dateimanager HD (Root)
– Nova Launcher
arunas ukPer aspera ad astra, we rock the Tablets !
Oma JB 4.2.2 multi-window v1.1
- latest kernel #412
- bug fix mobile networks
To upgrade from v1.0 just tick parameter, kernel, system.
2014/02/24
Hi. There must be some big problems with pipo s6! My first one worked only two days. Black screen, wont startup. Reset wont work. I sent it back and bought new one from other seller. So this second one worked for 3 days till it did same as first one! Shipping back is expensive so i opened it and disconnected the battery and then it did startup. The connector for battery is melted. To much heat i guess when they did solder the connector. Anyway. Now i have problem when the tablet been in standby for couple of hours the touchscreen wont work! I have to press the onoff button several times and it takes around 3min before touch works again. Do u also have that problem? I got a new firmware from pipo that isnt released yet on their site. But this didnt solve the touchscreen wakeup from standby problem. What should i do? Seems its a software failure.Â
Typical picture at the German re-seller ODYS is that the defect-rate of tabs is somewhere in between 20 - 40%. You must be aware of chinese production tolerances and standards. However, two defects tabs is really back luck.
My tab runs stable with both kernel and under JB 4.2.2 and KK 4.4.2.
86 Guest(s)
Devices in use: Desktop (70), Phone (15), Tablet (1)
jessicapeterson
Riki111
andre92
firmwarefile
mongol
country822
