2013/01/18
i installed seems to be very ok first boot time aprox 5 minutes, then its ok g-sensor its very ok its rotating, wifi its ok connect and running very nicely, seems to be fast for now im running antutu benchmark Oauuuu 11818 benchmark antutu (cpu 3615 Gpu 5995, ram 1518, i/o 690) the best of the best !!!!!!!!!Â
This is the link :
http://www.mediafire.com/download/9u8ubwdpehy64gv/Voyager1_7inch_4.2_version1.0.zip
Quadrant scores 4565 . nicee!!!
please root this version admin thankss and fix the hdmi
 ALEXANDER SHEDDEN said...
HDMI don't work please fix it
2013/03/06
Hi !
There is a 1.1 version where HDMI is reported to work:
http://chinagadgetsreviews.blogspot.ro/2013/07/android-jelly-bean-422-v11-firmware.html
Ender
2013/01/18
I installed v1.1 from Â
its very ok works everything only partition its 1 gb and 5 sd card nand flash
i hope that you make a better firmware thanksss globula
2013/01/18
This version of 4.1.1 after i test it doesnt work properly at random times happen to me4/5 times freezes some time s give a blank page and block the tablet.and another times freeze the screen and show like the display are broken show like you have over and over eachother 4 screen and vibrating. Not stable at all. For now seeMs to be very ok the sumvision firmware.
2013/03/06
@djcristi:
You had a lot of problems / bugs but in the end you say the firmware is okay ?!?
Do you mean:
the 1.0 was okay (although no HDMI) and the 1.1 is not okay (freezes / bugs) ?
Both are supposed to be for the Sumvision that is why i am not sure what you mean...
Greetings,
Ender
2013/01/18
yes version 1.0 its originaly from sumvision voyager and its stable i think i dont remember if  i had problems and v1.1  has bugs its from  Firmware 4.2.2 from PIPO S1S  Customise kernel  not from and for sumvision voyager....
- Firmware 4.2.2 from PIPO S1SÂ
- Removed Chinese applicationsÂ
- Added rootÂ
- Default language EnglishÂ
- Customise kernelÂ
- G-sensor is operating
- Camera is working
- HDMI output is working
- Antutu produces about 11.647 points
- Wifi Display Miracast supportÂ
I have just posted two custom firmwares designed for PiPO S1S and Sumvision Cyclone Voyager 7".
These two firmwares have not yet been tested on the PiPO S1, please report how it goes for you.
2013/04/09
Saw this on the sumvision site , not sure if it will work or not for pipo s1 (don't have time to try) , if it does it will need to be rooted and data expanded.
FIRMWARE 4.2 UPGRADE FOR VOYAGER 7 INCH ONLY 16/01/2014
http://sumvision.com/product/cyclone-voyager/voyager7-choice-support.php
http://www.mediafire.com/download/3q8eae80hbeqah0/voy_1_2014_4_2.zip
Don't buy from pipo-store.com.
Thanks for the tip otyg.
If PiPO S1 owner want to try this firmware, I am interested in their feedback, then I will make a custom firmware based on this version.
As I mentioned, I first need confirmation that it works properly on the PiPO S1.
Thank you.
105 Guest(s)
Devices in use: Desktop (94), Phone (11)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
