Here is an Android 4.1 JB rooted firmware for the PIPO S1 (DS733) tablet based on latest official update from Pipo (pipo_S1_software_english_version_20130325.zip).Â
Build information:
Kernel:Â Linux version 3.0.8+ (root@wzq-G41M-ES2L) (gcc version 4.4.3 (GCC) ) #226 SMP PREEMPT Tue Mar 19 11:29:06 CST 2013
Android 4.1 JB:Â PIPO/DS733/DS733:4.1.1/JRO03H/20121010.100452:eng/release-keys
Based on the build signatures it seems this firmware appears to be very similar to previous Chinese update (2013/03/20)
- root with latest SuperSU version 1.25 (free version)
- increased space for application (/data partition) to 2 GB
Download:Â kasty-pipo-s1-ds733-41-20130325-rooted.zip
Flash with Rockchip Batch tool, use Restore button.
copywriting4u, fratello, jox, pws31, KuJoe, chuck007, smithysmith1980, davidncx, al5911, Gypsygirl13, hwl2009, spiconi, enderffx If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/03/25
thank you and great work .I don't want to start my first post with a question but has any one tried both the march firmwares pipo's official (eng+chin)Â and ARCHTABLET's admins (eng+chin) rooted firmware ?.and which one seems to be the best on both ???. last time round the December Chinese rom seemed to be the winner since roman based a tnt rom off it.
The following users say thank you to smithysmith1980 for this useful post:
ultrarain, al5911As I mentioned on post #1, the English version Pipo release seems to be the same Linux kernel and Android system, they just changed the language settings and maybe some apps.
For me it's not real point having two (almost) identical versions, I actually removed my previous custom firmware release based on the Chinese version.
smithysmith1980 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/03/25
good question djcristi2001 as asked on flashmyandroid .if the Chinese version was fixed i.e removed bad apps/widget like admin was going to do before the newer English rom came out.would it make it better rom than English rom .or like admin said are they to similar to put the time in (which i do appreciate) to fixÂ
Well, we don't have the resources or time to test all the firmware builds from the manufacturers for all the devices we support. It's really up to you guys to test and report which firmwares run the best, then we can have a look about rooting and optimizing / cleaning them.
You cannot modify the image like that, you need to compile tools in linux, it is a little more complicated.
2013/01/18
globula_neagra  please tell me if exists the posibility to make android 4.2.2 with working wifi because i manage to install from oma android 4.2.2 and wifi fix but not working its conecting but with out connection to working ...
please make posibil some version android 4.2.2 for Pipo S1 not Pro or s1s because i try their officialy firmware and the touchscreen not working at allÂ
i wait for pipo.cn to release android 4.2.2 for Pipo s1 but no effect...
only if oma or someone else try to make oma version android 4.2.2 and rezolve the wifi problem somehow,
 thanksÂ
ms mult Globula neagra aci Cristian.
Respect Cristian
2013/03/06
Hello !
One question:
I have a general problem on my Pipo S1:
I can flash every Firmware using the RkBatch Tool (like this one, THANK YOU) but i can not flash any of the other Firmwares that ise the RkAndroid flasher (those firmwares that are split in several parts , boot / kernel / recovery...).
Do you have any idea what i am doing wrong ?
If i try to flash any S1 Firmware with the RkAndroid tool my S1 freezes before booting !
Then i can reflash with the Rk Batch Tool and all is good but i have a very limited choice of Firmwares AND i cannot exchange the kernel (which is what i want).
Thanks for help !
Ender
you should be able to side load the kernel also via adb, or any other terminal app
2013/03/06
---edit: can flash now, stupid mistake ----
Hello Globula !
Ah okay !
Thank you for the hint, dou you have any link to a howto ?
The thing is i can flash a kernel via RkAndroid (only "checking" the kernel file) but only get frozen boot afterwards.
I guess it is flashing the kerne to a wrong offset.
It really bothers me that "all the other" split-file-based Roms do not work.
But for now your suggestion is great if only i knew how to do it.
I can get an adb promt or use the root-terminal but i do mot know the commands...
Greetings,
Ender
put the kernel on the sdcard
adb shell
cat /proc/mtd
dd if=/sdcard/kernel of=/dev/block/mtdblock1
sync
This is just an example, you will find the exact mtd with the cat proc command
After you flash it, reboot the tablet.
enderffx
 thanksÂ
Respect Cristian
It depends on the manufacturer if they will release or not a 4.2.2 upgrade.
It is worth asking also OMA for some support.
2013/03/06
globula_neagra said
put the kernel on the sdcardadb shell
cat /proc/mtddd if=/sdcard/kernel of=/dev/block/mtdblock1
syncThis is just an example, you will find the exact mtd with the cat proc command
Hello Globula !
Thanks !
At the same time i found yet another way that i tried:
flash_image kernel kernel.img
That worked fine, got to play around
Greetings,
Ender
58 Guest(s)
3 Guest(s)
Devices in use: Desktop (54), Phone (4)
hans41
rickybk
soniya07
ironmangitar
