What Pipo P9 to get?
stevec59
2014/02/08 - 20:26
Hi Guys,
I'm a bit torn about what Pipo P9 to get. I phoned Digital Playwold and they tell me that the Pipo M9 (1280 x 800) is no loner available, so anyone selling them is selling old stock. I can get the Pipo M9 on Amazon for £161,but that has to come from abroad, so Do I go fro the Pipo Max M9, or do I go for the 3g version, I'm not likely to use it out and about, so think I might as well save the extra £25?
Thoughts?
Steve
pipotablet
2014/02/08 - 22:30
I bought Pipo M9pro 3G in early Jan . Wifi is a big problem and as you know a tablet without wifi is like a fish without water. This tablet without wifi should not be on market and its not just mine you can read about it on this forum and any others where it is discussed. The GPS does not work either. There is a review on XDA very misleading. google Pipo wifi is your friend
But otherwise its great screen processor etc its top class. Speakers at back not great.
I also bought a Chuwi V88s (exactly half the price of Pipo)with 8" screen and its brilliant . The V88 also had wifi problems but was sorted with introduction of 88S version.
just my 2 cent. Good luck
The following users say thank you to pipotablet for this useful post:
stevec59
Pipo M9pro3G
Chuwi V88S
Zenithink C-91
MTK Phone
stevec59
2014/02/09 - 10:02
Thanks for that, but I'm a bit confused, maybe you can clarify, you said:-
This tablet without wifi should not be on market.
As I understand it the M9 and the M9 Pro both have WiFi, I read a review on the M9 and it said that the WiFi was good. I have read that the GPS is poor, so that kind of point me towards the M9, I'm just a little worried not buying it from a UK Dealer, I would think that returning it overseas is a pain
Thanks for your other tablet Suggestions, but I really want a 10".
A friend of mine has the Lenovo s6000, she says it's good, I found a review:-
http://www.notebookcheck.net/Review-Lenovo-IdeaTab-S6000-Tablet.100178.0.html
It's only got 1gb of RAM, so a bit underpowered and
features a quad-core Cortex A7 with a clock rate of 1.2 GHz. The SoC from Mediatek is called MT8389 and is supported by a PowerVR Series5XT.
So, I would expect the P9 to be better
Steve
stevec59
2014/02/26 - 20:02
Hi Guys,
I've just got my Pipo MAX P9. I hate reading, is there a video somewhere that I can watch to find out everything? If I can download it so much the better.
Steve
75 Guest(s)
Devices in use: Desktop (58), Phone (17)
cutierogue
hans41
