2013/12/30
Hi there, i've just updaed the firmware on my Pipo M9 Pro and everything seems ok until the welcome screen, the touchsscreen doesn't work on 80% of the tablet and the 20% that does work operates the opposite part of the screen (it's basically un-usable). The update is from the official pipo website (firmware version attached below), I have tried various other ROM's included Riley, Kasty etc and the same happens, boots up fine but touchscreen not working.
Anybody had experience of this before?
M9pro_software_3G&WIFI_english version_20131120
Are your devices OK before the upgrades? the touch screen I mean. then you should go back to the version #353 Novembers release. it is stable by then. down load the CWM recovery and then do a complete wipe of the dalvik cache/and nand memory before flashing a new firmware.
If before the upgrade your device is NOT OK then it is a wire or cable coming loose. I have no problems by using KASTY ROM from start out of the box till now.Please do a complete wipe of nand/dalvik cache before flashing any new version of firmware.It shouldnt be that ALL firmware you flash giving you the sticky touch screen issue (this is due to not doing a full format of dalvik cache delete and nand format from my experience)
gg69About Me LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
2013/12/29
I got the same recommendation from Pipo (rk3188-1007-20131210.img) but it didn't help. Just a minute ago i got an email from pipo telling me it is HW filer you need to add 10K resistance but it doesn't seems right because it was working before the upgrading. I will try CWM recovery method that you suggested. Thank you for the tip cracktech.Just question after erasing the dalvik cache/and nand memory via CWM I need just to turn off the device and flash it using e.x RileyROM flashing tool?
Yes you do that! Wipe via CWM and then standby the RkBatchTool (on the PC) with the necessary firmware, now I recommend you use the latest Dec firmware version for Wifi only device and the latest for the 3G version (I dont follow that model too much, coz I have WiFi only device).
Please do a check up "under the hood" for wires that if not assembled properly at factory will come loose at our (customer) side.
After the wipe dalvik and nand (the device is in the ON/power On leave it at that) condition and with the RkbatchTool already loaded with the firmware *.img file, you can attached the USB OTG cable from PC to device (wait for the necessary communication/drivers loaded and start the flashing process.
Dont bother to read the upgrade guide (in MS Word format) that comes with the the RKBatch Tool, please read the attached file I prepared in *.pdf format.that instruction that came in MS Word format is counter to the one we recommend in the upgrade process. In there it says press the "upgrade" button whereas we recommend "restore" button (I have read in other forums that sometimes using the upgrade buttons can softbrick your device).
Hope that you are Ok with the instructions , and please do check under the hood or else return it to seller (if it is not from China!).
2013/12/30
Thanks for the advice cracktech, is there a way of running CWM recovery using my pc, I can't get access to the tablet because of the touchscreen problem. If there is no way of wiping dalvik cache through the PC I suppose I will need to purchase a mouse for tablet and run recovery from there?
Yeah just like gg69 says just plug in any mouse wireless or wired through an OTG adapter it is the other usb port (not the one you use to flash) see picture it is the furthest to the left of the camera.(Micro USB to FEMALE USB OTG adapter).
But if the wipe and reflashing doesnt solve your problem I'd advise you to return the device to seller coz it might be hardware related (it was marginallly working after coming out of the factory). Dont use any software downloaded from China site (it is corrupted copy).
Please use this guide to ugrade your firmware and not the one that came inside the RKBatchTool folder.
56 Guest(s)
Devices in use: Desktop (49), Phone (7)
