solving all wifi and 3g problems with pipo m9 pro 3g
devilmc
2013/10/31 - 01:26
for all those who are experiencing problems with wifi.
In all kasty roms wifi didn't work, always disconnecting, loosing power, not holding the connection and 99% of the times had to turn it off and then on again.
I solved all these problems with Riley 1.9 test 2 rom, now wifi is ok for hours and 3g max speed always on and recognizes all operators, however the kasty one was way more fluid and performing.
Kasty, can you make your next rom solving all wifi, 3g, problems taking a look at the riley's 1.9 test 2? then your rom would be perfect
galmiche
2013/12/16 - 14:06
Hi all
Had this Wifi problem been solved now?
Thx
Hervé
PiPO M9 PRO 3G
Zeggi
2013/12/17 - 17:02
well for me the fix did work for a few days, the big issue is the poor solution of the ground wire as many other "cheap" brands and android sticks. seperate ground from the built-in wire and your good to go. there is a thread in the forum where you can find the riley rom. Thats the best solution for best and stable connection.
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2013/12/17 - 17:16
It is not the KASTY ROM or RILEY ROM, it is the kernel and other updated files pertaining to this device. I had problems connecting to Wifi on previous version of KASTY, factory firmware but with the last 2 updates from the factory ROMs in which the factory (said that they did update some files to improve the wifi and it did) update to resolve the Skype and Wifi iisues.
I have no problems with wifi connections in the last 2 updates. My problems with the previous update was that wifi is on but no internet connection (no blue icon) I have to install a static IP app to auto start at boot up to solve this problem. Now it doesnt have that problem anymore.
But if I install the static IP app from Playstore in the latest updated ROM then I loose the internet connection (no blue icon) until I uninstall the app. I dont think it is due to the wifi antanae, cause mine have no problem even outside the house about 40ft away from my router.Try the latest updates.
Zeggi
2013/12/17 - 18:55
Im sure they managed to adjust wifi issues for most people by adjusting with sw/fw updates but what im talking about is the mayor error from production, using 1 and same wire for positive and ground, sure ground is isolated a few mm. Simply put you dont run the same wire for ground and positive.
So for me by just separating the 2 gave me max wifi connection and speeds of 38/32mbit/s which is way better than before and also stable all the time, no drops no nothing.
Im not saying they managed to make it better by sw its just, you dont run the same cable for ground and positive.
cracktech
Malaysia
Forum Posts: 432
2013/12/17 - 21:33
OKay youre right! Maybe my device is just lucky it didnt have that wires entangled.
92 Guest(s)
Devices in use: Desktop (76), Phone (15), Tablet (1)
3nf
lesfurets
lbalexa001
rkg2303
sergey-tax
houseofcandy
