[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2013/12/26)
Amrahil
121
2014/02/02 - 20:12
Hi, I've used this ROM for a few days on my tablet now and it works great! Infact the only thing I miss right now is miracast working properly (as mentioned page 1 as well.)
Now on my Galaxy S3 I've noticed that when I flash a new stock ROM on it, Miracast won't work initally until I reset the binary counter. It connects and everything up until the point when the display is supposed to appear and then fails, citing 'Hardware something something'
The Pipo tablet does the same, connects and everything up until when the screen is supposed to appear but then fails with no message.
I wonder if this could somehow be related? Is the binary counter even a thing on tablets? and might it be possible to reset? Then I could test to see if miracast will work afterwards.
The following users say thank you to Amrahil for this useful post:
Lucda
Djuganight
Portugal
Forum Posts: 98
122
2014/02/02 - 23:08
Can you port this kitkat to pipo m9?
Pipo P9
s7yler
Forum Posts: 17
123
2014/02/07 - 20:26
Will this work on the Vido M10? I guess it has similar specs or?
diogo180794
124
2014/02/12 - 22:54
Cheers! Automatic Brightness is not working... Is there a way to fix this?
korrupziony
125
2014/02/13 - 12:32
I fix it with Poder Troggles app.
korrupziony
126
2014/02/13 - 12:39
Two Xposed: 1 Gravity box to use inmersive mode on all apps . 2 xhalofloatingwindow to use multiwindow. both works fine
EDHUNTER
Forum Posts: 22
127
2014/02/15 - 16:14
tested firmware 4.4.2 on my Pipo max-pro version 3g
spectacular firmware, the wifi is working fine, all settings without any bug, quick startup, this rom very stable, does anyone know where I can find the stock rom 4.2.2 official jelly bean for my Pipo max-3g pro version? want to have only for future testing, no new post in the forum ...
congratulations to the developer.
uli-hh
Forum Posts: 31
Thanks Received: 8
128
2014/02/15 - 17:22
here is the latest 4.2.2 PIPO stock rom:
"update_M9pro_OTA_20131209.img" (480MB zipped Archiv)
The following users say thank you to uli-hh for this useful post:
EDHUNTER
diogo180794
129
2014/02/23 - 14:58
Hi there! Don't know why, but most of the coolest games in Android are crashing. I'm trying to play Most Wanted, it crashes. I'm trying to play Tintin Adventures it crashes.... Seriously, I don't know what to do...
Does anyone have an idea?
EDHUNTER
Forum Posts: 22
130
2014/02/23 - 16:39
diogo180794   some games are still not compatible with android 4.4.2 kast kit, games like real racing 3 need for speed wanted mosted not run 100%, some are with the audio bug (RR3) ... wait for updates of those games that has not are compatible with the firmware
Thanks Received: 3171
131
2014/02/23 - 16:53
Updates can also be expected on future firmwares, current KitKat firmware are still preview versions that should be improved by the manufacturer, we may see stability and feature updates in the firmwares these coming weeks.
EDHUNTER
Forum Posts: 22
132
2014/02/23 - 17:12
but will they release an update for these days? for that matter even with the incompatibility of some games this firmware 4.4.2 kast kit, I think kind of hard to release an update pipo stock better than this ... beautiful tabalho should be rewarded
derricktanyz
133
2014/02/24 - 11:31
I tried to downgrade kitkat to 4.2.2 rileypackage but on halfway i found the broken andriod logo so i restarted it. Now when i start my tablet, it goes on to broken andriod logo screen and can't able to go into usb mode, what must i do guys???
ludoke
Forum Posts: 85
134
2014/02/24 - 11:43
Did you read the manual from rriley?
KitKat has a changed bootloader and that couses the trouble you have now.
derricktanyz
135
2014/02/24 - 12:23
Ya. I'm fine. Just do a hardbricking of the pipo and restore it to the 4.2.2 rileyrom. Kitkat couldn't use gps and mainly issues with some games such as Hayday etc. So i thinking temporarily converting back to 4.2.2 will be more stable. I might be switching to Kasty rom 4.2.2 as it might be more stable. Thanks for your reply.
113 Guest(s)
2 Guest(s)
Devices in use: Desktop (110), Phone (3)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
