2013/03/26
Kati said
Hey guys!
I need help!!! I installed the new ROM. Skipping the fact that 3G does not work but I have a much more serious problem. I installed CWM Recovery. There were problems: Can not mount backup path. CWM error mouting /sdcard. Please, help me!!
Kati, I am new to all this so I may be wrong....but I have noticed other comments that CWM will not work with 4.4 because there is a difference within the file structure between Jellybean & KitKat. Unless someone can advise on how to get CWM working then I suspect you are stuck! Perhaps an updated CWM will be produced that bridges the two. If you are stuck and need to get at your CWM backup then I suspect you will have to go back to Jellybean & restore from CWM. Then do a backup perhaps using Titanium and go forwards to KitKat. However I would note I had problems reloading a Titanium backup in 4.4 (but that may be because the backup was taken from a different device running 4.1). Be careful if you do decide to go back to Jellybean. Read the forums and advice because it seems easy to 'softbrick' the tablet (I tried 4.4 twice, on one occasion I went straight back to Kasty 4.2.2 without an issue; on the second occasion I tried going back to another ROM and softbricked the tablet).
2013/10/26
alanofamersham said
Kati said
Hey guys!
When returning to Jellybean you have to tick loader in RK batchtool because KitKat uses his own loader.
Quick note to let you know I have posted a small update, see post #1.
- Edit 2014/01/14: updated SuperSU to latest version 1.89 (free version)
- Edit 2014/01/14: added Google Experience Launcher (GEL) in addition to PiPO's stock launcher
- Edit 2014/01/14: use optional package to fix broken apps (Contacts/People and Calendar sync)
Download: kasty-pipo-m9_pro-442-20131226-rooted4c.zip
tooden, mattiesrag, Alpha_B, pipotablet If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
You may try that (so far un-tested) :
2013/10/26
paulanchor said
Thanks for the kitkat, however my pipo m9 pro 3g location mode is off dont know how to restart, maps cannot find gprs, so not able to use gps location. Any help here?Greatly appreciated
3G works on Kitkat(version from Freaktab with i have used)
As well known GPS is NOT...NOT working on KitKat for now,there's no GPS module in it.
2013/09/13
Hey Paulanchor Just wish you guys would READ the entire blog before asking the same questions over & over & over & over.......
We all know that GPS does not work yet (BETA version). Also auto brightness does not work!
3G works perfectly on ARCTABLET rom (can't speak for FREAKTAB)
Thanks to Admin - a great job.
2014/01/08
My first post on this forum. Hi to all!
I've recently purchased the M9 Pro 3G version and I'm in the process of testing different ROMs.
What about battery life with this one?
With my current ROM, it never stops the wifi, even with the only when charging option selected, resulting in an important battery drain.
Thanks in advance.
2013/10/26
belier said
My first post on this forum. Hi to all!I've recently purchased the M9 Pro 3G version and I'm in the process of testing different ROMs.
Thanks in advance.
I recommend Finless 1.5 in every way ,smood ,stable and Gps whith a lttle tweack and great battery life.
2014/01/08
Thanks in advance.
That's the one I have installed. But having wifi always connected, and not being that good, is draining the battery.
2013/10/26
Thanks in advance.
There's somting wrong with you divice ,my expierence is that no friendler rom then Fin less
2013/12/10
Thanks in advance.
Try the app deep sleep battery saver. It's perfect for you want.
2013/12/10
Thanks in advance.
Kasty rom works much better than Finless. It's a fact.
80 Guest(s)
Devices in use: Desktop (72), Phone (8)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
