[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2013/12/26)
darevil102
Forum Posts: 35
61
2014/01/10 - 01:28
Replica said
I can't install the rom.
It throws me the message:
<Layer 2-3> This operation didn't do, because of not supporting!
Restore Done Success<0> Fail<1> Time<0>ms
The button saying upgrade tells me the same.
I tried to reset, hitting with a needle the reset hole + power button, but I got the same message. In Rockchip Batch tool, the connected devices  box paints in pink the number one, with "2-3" under it.
Anybody with a possible solution?
Thanks.
Read all the manuals before...
Replica
62
2014/01/12 - 10:57
Thanks.
Thank you, cpt. obvious. As you would know, this doesn't give me any solution.
darevil102
Forum Posts: 35
63
2014/01/12 - 11:35
Thanks.
If you try to install the rom with a pink box, you need to read more manuals, cpt. Stupid...
BOZ77
Forum Posts: 15
64
2014/01/12 - 12:20
Good morning. test version of 3g. 3g ok. gps not working. luminositer self neudorf not work. non-fluid if the novelist is perfect and much more fluid than other chromium thank you
tunguska
65
2014/01/12 - 18:26
Hi there,
everything works great here with that firmware, even 3G – as described in the thread. Today i wrote an email and found out that aparently the contacts app is missing. is there a way to add the stock apk? There seems to be no sync of the contacts without that app…
Thx and greetings
tunguska
Thanks Received: 3171
66
2014/01/12 - 20:10
The missing/non working Contacts app should be fixed soon.
Kati
Forum Posts: 14
67
2014/01/12 - 23:19
Hey guys!
I need help!!! I installed the new ROM. Skipping the fact that 3G does not work but I have a much more serious problem. I installed CWM Recovery. There were problems: Can not mount backup path. CWM error mouting /sdcard. Please, help me!!
ludoke
Forum Posts: 85
68
2014/01/13 - 11:01
Kati said
Hey guys!
You can backup with Titanium Backup
Kati
Forum Posts: 14
69
2014/01/13 - 11:38
I dont have backup titanium!!! Does this mean that you can not fix it?
ludoke
Forum Posts: 85
70
2014/01/13 - 11:51
Oh,oh you find it in the Play store,Why messing around with CWM if you don't know even this ?
darevil102
Forum Posts: 35
71
2014/01/13 - 14:01
Ludoke, you don't understand nothing. It's impossible to restore a security copy from CMW with Titanium Backup.
She has a problem with the CMW backup path and your solution is to install Titanium Backup... OMG!!!
ludoke
Forum Posts: 85
72
2014/01/13 - 14:14
She's not talking about security back up. CWM is not an original appfrom Pipo? but a tweak from Arctools for Pipo. So, it must be possible to make a security(rom back up you mean,i think?)
There must be other ways to do that ,maybe Rom Manager ?
darevil102
Forum Posts: 35
73
2014/01/13 - 14:25
CMW is a tweak from Arctools????? Please, read about CMW in google...
Rom Manager uses CMW or TWRP to work...
ludoke
Forum Posts: 85
74
2014/01/13 - 14:29
If you read her first post you see she's having CWM, maybe it's in the settings of CWM to setup a backup path ? Like in Titanium.
BOZ77
Forum Posts: 15
75
2014/01/13 - 20:03
hello the sms ok is application DINAMOTXT
101 Guest(s)
Devices in use: Desktop (90), Phone (11)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
