[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2013/12/26)
alanofamersham
46
2013/12/29 - 16:47
hmsr21 said
hmsr21 said
Well, to be fair, when I tested it the navigation was really smooth and snappy. The graphical problem I currently have when using the tablet in portrait position of showing purple lines across the screen, didn't happen. Also, I loved the new keyboard and feel of the new ROM. Can't wait for them to release the final product!
I would say, watch this space...
Also, antutu tested at 14000 instead of the old 18000 on JB 4.2.2
Did you reboot before running antutu? You may have had programs in background. I tested at 15,400 then rebooted, new result 18,461!Laugh
alanofamersham
47
2013/12/29 - 16:58
hmsr21 said
Mine (wifi only) made 18.200 points...
Very fluid navigation, no extreme battery drain, lot of apps in google play.... great rom! Waiting for the definitive version.
How long does your battery last?
I bought my first Pipo M9 Pro and all I can get out of it is 2 hours max just using Wifi and internet browsing!
Not sure if this is normal. Can you let me know how much a 7000mAh battery should last? (According to Pipo specs it should last up to 9 hours!!!)
Not normal. I have new tablet. Charged then used until battery low then recharged etc. I did read that you should avoid 'topping up' battery. I reloaded 4.4.2 around over 4 hours ago and have been on WiFi since, just checking things out, trying Skype, BBC iPlayer, but no videos yet. Battery at 68%. Will load and try a video later and will update this post. Watched 1hr of video over WiFi plus listened using Bluetooth headphones. Used 16% of battery.
bathool
48
2013/12/30 - 15:27
Do you have any information about KitKat for pipo m9 pro (3G version)?
darevil102
Forum Posts: 35
49
2013/12/30 - 15:39
Here you can check for updates:
http://pipo.cn/En/index.php?m=Product&a=show4&type=2&id=286
eekram08
50
2014/01/02 - 12:26
anyone who can share other mirror sites for this firmware? my downloader always stop with no resume capability.
faysoft
51
2014/01/02 - 13:31
where is GPS ON/OFF?
ludoke
Forum Posts: 85
52
2014/01/02 - 13:45
There is NO gps module in it
alanofamersham
53
2014/01/02 - 20:08
If you read through this thread you will see many people noted that GPS module is missing. Plus you will see warnings about loading this ROM which is a work in Progress I believe. you may have some problems loading an older ROM back. If so read through thread carefully (and other threads about bricked Pipo M9s).
danielp
54
2014/01/04 - 01:58
I have the M9 Pro with 3G and this rom has 3G in it... works perfectly.
So far this rom is the best I've had on mine.. so much more fluid, apps open much smoother and faster, haven't had any apps hang yet
so far loving it!!
G B
Forum Posts: 21
Thanks Received: 5
55
2014/01/05 - 06:13
Can anyone confirm about MIRACAST working on this ROM???
the5th
56
2014/01/05 - 13:54
Does the CWM version included with arctools work with this ROM for anyone? I know from my phone that all the custom recoveries had to be updagted to work with 4.4.
I installed CWM on my tablet but I can't do anything with it, I just keep getting mount errors. The only thing it does without a problem is reboot system.... Any advice? I have a few zips I'd like to flash....
Thanks Received: 3171
57
2014/01/05 - 17:45
I've updated post #1 with some screenshots.
G B, I tested Miracast, trying to display remotely on a Minix Neo X7, it didn't work for me. I haven't yet investigated where the problem could be.
t608
čr
58
2014/01/07 - 00:25
no gps
ludoke
Forum Posts: 85
59
2014/01/07 - 05:46
t608 said
no gps
Newbies should read the thread before posting,everyone here know about GPS on KitKat.
Replica
60
2014/01/10 - 01:17
I can't install the rom.
It throws me the message:
<Layer 2-3> This operation didn't do, because of not supporting!
Restore Done Success<0> Fail<1> Time<0>ms
The button saying upgrade tells me the same.
I tried to reset, hitting with a needle the reset hole + power button, but I got the same message. In Rockchip Batch tool, the connected devices  box paints in pink the number one, with "2-3" under it.
Anybody with a possible solution?
Thanks.
100 Guest(s)
Devices in use: Desktop (89), Phone (11)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
