[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2013/12/26)
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
211
2014/08/06 - 13:53
From the first day since I own the PiPo M9Pro and my previous Android devices (AMLOGIC , MTK, SPRD) I was using either a Vista or Win 7 32bit (now Win7 32bit for RK31xx) for my newer MTK devices (OctaCores) I am using Win 8.1 I've never encountered the problem that you have mentioned.(RK31xx). Please use DevManView to remove other drivers for Android devices from your PC first (go to : http://www.nirsoft.net ) you will see something like the picture attached wher you must have ADB driver already installed and as you can see I have other drivers like A880 (LENOVO A880/889 MTK phone drivers) and you should also see "Fuzhou Rockchip drivers" (if you dont see this driver you will not be able to flash your device)
Download "easy Sample-DevManView.jpgImage Enlargerrockchip driver installer" (google for it) if it is not present on your PC.
4thjak
Advanced Member
Forum Posts: 115
Thanks Received: 5
212
2014/09/25 - 18:45
Any recommended overclocked kernels for this rom?
Pipo M8pro
Pipo M9pro
Pipo P4
arcrsc
213
2014/09/25 - 19:51
yes only in the case you need for some VERY important, although with a little more velocity.
thewizard207
214
2015/01/09 - 02:03
hi man, i got a "Xtratech Iguanapad M723" bricked :S
i have tried with a lot o ROMs to repair it, this tuto will help me?
The device is a rockchip rk3026
originally it has this firmware rk3026-eng 4.4.2 kot49h download
futzmaster
Forum Posts: 37
Thanks Received: 4
215
2015/02/08 - 11:25
At Freaktab i found the newest compiled system.img and boot.img
(they got the sources from Pipo...)
http://www.freaktab.com/showthread.php?19014-Pipo-Project-M9Pro-kernel&p=280242&viewfull=1#post280242
in this link is a overclocked kernel....
http://www.freaktab.com/showthread.php?19014-Pipo-Project-M9Pro-kernel&p=280355&viewfull=1#post280355
and they already made a new image:
http://www.freaktab.com/showthread.php?22964-Pipo-Project-M9-Pro-ROM-testing
Maybe you would have some time and look into that and you could provide a new kasty rom?
113 Guest(s)
Devices in use: Desktop (109), Phone (4)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
