[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2013/12/26)
futzmaster
Forum Posts: 37
Thanks Received: 4
Piperos
Forum Posts: 13
182
2014/04/08 - 07:06
I installed the multiuser patch from the recovery tool, but I don't know how to switch user, can someone help me?
futzmaster
Forum Posts: 37
Thanks Received: 4
183
2014/04/08 - 12:21
http://thedroidlawyer.com/2013/12/how-to-enable-multiple-user-accounts-on-android-4-2-and-above/
didn`t read it but from the pics there it should tell you how to do it ;)
darioM85
184
2014/04/08 - 18:49
hello guys I have a problem with my pipo m9 pro. yesterday is that the power button does not work anymore and now it's turned off and will not turn anymore. If I put it on charge comes on the screen with the word PIPO and a little later we see that the battery is charging and the screen turns off ... how do I start it?
EDHUNTER
Forum Posts: 22
185
2014/04/08 - 19:23
 hello darioM85 your tablet probably came into looping, the firmware must have been corrupted for any application or UPDATE ota.rename certain system files, build.prop can make your tablet into a deep looping ... try reinstalling the rom using the tool rkbatch toll, use the restore button if the issue persists should be no problem power button on your device ... I have helped ...sorry I'm using google translator, and words can not be too certain
Piperos
Forum Posts: 13
186
2014/04/09 - 20:24
The problem is that when I press the "add account" functionality the tablet reset itself.
By default it has already two users (one of them had a chinese name) but I can't find a way to switch between them: I see no way to find the usual list of icons with the user accounts that should appear when dragging down the menù
trellosgavros
Forum Posts: 11
187
2014/04/10 - 08:53
Hi !
A small newbie question : if you go to Location and click on Mode and select High Accuracy then the GPS toggle turns on. This means that GPS is working or not ?
Thank you !
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
188
2014/04/10 - 12:54
Yes, when you switch On GPS under this KitKat (it doesnt have the usual GPS On/OFF settings) Then when any GPS app (Sygic/Maps/GPS Test included in the ROM)has turn the GPS on you will see small pear shaped icon appears near the the Battery/ WiFI icon.
IF the firmware doesnt come with GPS will your app (requring GPS) run?? I was also dissapointed at first in not finding GPS ON/OFF switch in settings but now after using it for a few weeks I understand it better. You were not here when we were on 4.2.2 since August 2013 when WiFi problems (it doesnt connect even after a few minutes until the latest update only then the WiFI was OK)
Now it is instant ON as soon as the homescreen appears it is already connected (although I would prefer a blue icon than the white icon since you dont know whether it is connected to Internet/Google servers or just WiFi local access)
cracktech
Malaysia
Forum Posts: 432
189
2014/04/10 - 13:06
MultiUserSettings.pngImage EnlargerPiperos said
Why use a multiuser patch? When it is already in build in the ROM (recipe for disater) it is set for upto 8-users I reduce mine to only 4.
Piperos
Forum Posts: 13
190
2014/04/10 - 13:40
You mean in the updated rom that I can get from this thread?
The problem is I don't use windows (only Linux) and I don't know how to make the rom upgrade
First of all this ROM doesnt have to use patch to ADD Multiuser. In order for you to reduce the number of users find for the file in root directory go to /system folder proceed to the bottom of the /system folder and you will find "build.prop" read/edit a line inside there that says something like "number of users=8" edit that to the number you think is realistic for you for me I change that to "4" even then I will never ever use more than 2 users.
You ONLY use a patch (I have available) to remove Multiuser capability of the device, you dont have to add Multiuser patch in KASTY 4.4.2 ROM and GPS is working that is why I migrated to KitKat,  before I refused to migrate to KitKat first version because the GPS is not working now it is working and dont anybody doubt that unless that wrongly flash the first version.
Please dont put undo pressure on ADMIn as he has to have donation for his purchase of another pad the ONDA V975m with M802SoC (AMLOGIC device) this one is a rocket 32000++ Antutu score!.I will be donating towards his purchase of this ONDA.
garbuya
Forum Posts: 11
191
2014/04/10 - 15:17
Since this is the topic for 4.4.2 KitKat custom root firmware i assume that you have this version on your tablet. Is it correct? if yes, then GPS finally works with 4.4.2?? After I switch to 4.4.2 I don't even have this option any more in Location settings! It like GPS does not exist at all! I know this is a common problem with 4.4.2 and still waiting for updates. Did I miss something?
Sorry, I have no idea why my post is inside the quote and how to take it outside.
trellosgavros
Forum Posts: 11
192
2014/04/10 - 15:58
I don't know, I followed the procedure exaclty as mentioned in the first post and flashed the firmware in the first post. I have this option and the GPS is working. I don't know why the others say it's not.
Thanks Received: 3171
193
2014/04/10 - 16:08
This may help:
http://www.arctablet.com/blog/forum/firmware-flashing-on-rockchip-based-devices/flashing-rockchip-update-img-firmware-on-linux-rk_batchtool-v1-7-equivalent/
cracktech
Malaysia
Forum Posts: 432
194
2014/04/10 - 19:53
Read my thread #188 the GPS IS WORKING!! It is just that it doesnt have the usual ON/OFF switch like we are ALL used to on 4.2.2. It will auto turn on when any app requiring GPS is run. It doesnt show the usual "round" symbol on the top left hand corner like before, like I said a "pear" shape symbol will appear just beside the white WiFi icon.
I have run Sygic Navigation flawlessly, why so resistant to change (it only has different ways to switch on the GPS)
apalmero
195
2014/04/12 - 00:31
Any way to keep 2gb in data partition for applications (/data)?
For me 7gb is too much and will decrease the internal sdcard size. I'm using now a bit more than 1gb of apps and 2gb is more than enough so far. In the future (if I need) I can make a full backup with Titanium and flash a "4gb data partition" rom.
Thanks!
86 Guest(s)
Devices in use: Desktop (77), Phone (9)
swan12
heftpflaster
