[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2013/12/26)
Paul2482
151
2014/03/11 - 20:37
This is for both WiFi and 3G
EDHUNTER
Forum Posts: 22
152
2014/03/11 - 23:53
anyone have a detailed tutorial on how to revert to the original firmware 4.2.2 jelly bean? updated to 4.4.2 kast very good by the way but vairos ha alicativos that do not work well in this rom, including games that taste much like real racing 3 and mosted wanted that no longer work .... ps: I think the tutorial freaktab risky and understand complex environment because the correct procedure if not done can brickar tablet
Thanks Received: 3171
153
2014/03/15 - 13:00
EDHUNTER, arcrsc
strsoft
154
2014/03/18 - 03:54
has left a new version on 2014/03/06 Will we have a new custom based on this new version :)
Firmware upgrade
PiPO M9pro_software_OTA_3G&wifi_chinese&english_20140306   2014-03-11
http://www.pipo.cn/En/index.php?m=Product&a=show4&type=2&id=286
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
155
2014/03/18 - 05:37
This is NOT a KitKat ROM it is still 4.2.2 renamed to 4.2.4 to show that it is customised. This was discovered by users from other Forums.
arcrsc
strsoft
156
2014/03/18 - 14:57
did not know that ... thank you my friend, I thought it was the new Kitat 4.4 with 3G :(
cracktech
Malaysia
Forum Posts: 432
157
2014/03/18 - 20:16
This is the same as the latest KASTY #424 16-Mar update. By the way I always renamed my device to version 4.2.9 from the 4.2.2  (close to 4.3 but you cant name them 4.3 as the android build for 4.2.2 is 17 and 4.3 is 18 if you do that then the device will even fail to boot up and it will FC a lot of apps if it does manage to bootup. I did that just to differentiate my device from others M9Pro on the Google Dbase.(such a snob I am)
Dereck
Forum Posts: 15
158
2014/03/22 - 07:31
Firends,
having problems.
I`he updated with this fw in the past.
Now I want to update to teh new one.
I connect my pipo with usb to the pc and... nothing happend. Therre is no new devices.
Can you please help me?
jy_p
Forum Posts: 44
Thanks Received: 20
159
2014/03/22 - 07:38
Dereck said
Firends,
having problems.
You should not see a new device since you already have installed the drivers for it. Just start the flash tool and check if it detects the tablet.
Dereck
Forum Posts: 15
160
2014/03/22 - 07:58
 Rockchip Batch Tool version 1.7 also do not see device.
jy_p
Forum Posts: 44
Thanks Received: 20
161
2014/03/22 - 08:08
Your tablet is booted and USB debugging mode is off? You are using the USB connector on the right, not the OTG one? Are you using the cable that came with the tablet? PIPO's cable has longer connector which is required with this tablet.
162
2014/03/22 - 10:00
Firmware upgrade
We already have a custom firmware build for this firmware, if you look closely in our PiPO M9 forum section, you should find it.
strsoft
163
2014/03/22 - 21:56
Firmware upgrade
thank you my friend ... I did dowload here when you have some time I'll try .. good luck.
cracktech
Malaysia
Forum Posts: 432
164
2014/03/24 - 19:34
If that is so then when you want to reflash it you will have to use "power + volume up/down" buttons pressed at the same time while your other hand needs to click the batch Tool (hah,haha, haah need another person to help you) Please read my thread on how to recover from softbrick procedure which tells about the method and timing of presing the power +volume button.(Although yours is not softbrick but the timing of the pressing the buttons is critical for the PC to see the M9Pro/M9/M7Pro/ before you can start  RKbatchTool)
Dereck
Forum Posts: 15
165
2014/03/24 - 20:27
Thanks for advising for all.
Will try.
100 Guest(s)
Devices in use: Desktop (88), Phone (12)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
