[ ROM ] Pipo M9 pro Android 4.4.2 KitKat custom root firmware (2013/12/26)
ludoke
Forum Posts: 85
136
2014/02/24 - 12:40
derricktanyz said
ludoke said
derricktanyz said
I tried to downgrade kitkat to 4.2.2 rileypackage but on halfway i found the broken andriod logo so i restarted it. Now when i start my tablet, it goes on to broken andriod logo screen and can't able to go into usb mode, what must i do guys???
Did you read the manual from rriley?
KitKat has a changed bootloader and that couses the trouble you have now.
Ya. I'm fine. Just do a hardbricking of the pipo and restore it to the 4.2.2 rileyrom. Kitkat couldn't use gps and mainly issues with some games such as Hayday etc. So i thinking temporarily converting back to 4.2.2 will be more stable. I might be switching to Kasty rom 4.2.2 as it might be more stable. Thanks for your reply.
It won't work,you can not go back from 4.4.2 because you have another bootloader now.
You said you have the Android on his back and that means you are bricked.
Now you have to open you tablet and shortcut two pins of the Nand chip,you can read in rrileys first post from his topic how to do so.
Thanks Received: 3171
137
2014/02/24 - 13:03
I don't think this is very accurate.
It is possible to downgrade from Android 4.4.2 KitKat to Android 4.2 JellyBean using just Rockchip Batch Tool. I am currently making some tests and will post the procedure as soon as I am satisfied with the results.
ludoke
Forum Posts: 85
138
2014/02/24 - 13:21
I know it's possible with rrileys flash tool with that tool you can flash the old bootloader back but i assume that derricktanyz has a brick now.
People should read before flashing....
jy_p
Forum Posts: 44
Thanks Received: 20
139
2014/02/25 - 17:14
Does any one has tested the CIFS and TUN modules?
thanks,
EDHUNTER
Forum Posts: 22
140
2014/02/26 - 01:05
I tested 4.4.2 upgrade kit kat kat and downgrade to 4.2.2 on my jelly bean kit pipo m9 pro RKBatch_Tool_v1.7 3G using the flash tool,
would be interesting if there was a tutorial on how to downgrade to the original firmware 4.2.2 using jelly bean alum flash tool so that the rom works stable ...
derricktanyz
141
2014/02/26 - 05:56
Yup. I downgraded to 4.2.2 jellybean from Kitkat. Now having some issues, when you make the tablet rotate horizontal, it will tend to freeze at setting and some games. The hide status bar is kinda useless towards some games as it will pause the gameplay and stuck there, I didn't know this is firmware issue or what. But kasty 4.2.2 rom has more customized Arktool setting to install CWM easily and the deep sleep mode for tablet to save battery life.
EDHUNTER
Forum Posts: 22
142
2014/02/27 - 03:28
also had this same problem in 4.2.2 when kast downgraded, the Settings menu lock and the games run but with black screen image as the error persisted back to kast 4.4.2
DrDexter
143
2014/03/09 - 07:33
TUN module working good.
CIFS not tested
Found froblem with g-sensor in applications. G-sensor in system working good, turns screen like it should be, but in applications no reaction.
uli-hh
Forum Posts: 31
Thanks Received: 8
144
2014/03/09 - 14:57
There is a tutorial "Switching back to Jellybean from KitKat" on Freaktab.
The following users say thank you to uli-hh for this useful post:
EDHUNTER
diogo180794
145
2014/03/09 - 18:39
Good afternoon. I have a problem here. In every single app that uses the camera, the camera simply freezes. It only works on the default android app. When I use an app that need access to the camera, at the first second an image of what i'm trying to shoot appear, but then the image goes still. The camera freezes. Is this a known issue or its just me?
Thx
EDHUNTER
Forum Posts: 22
146
2014/03/09 - 21:30
diogo180794 said
some applications are not yet compaiveis with android 4.4.2 kitkat, try downloading others that are compatible ... I have helped ...
maly2006
147
2014/03/11 - 09:42
gemere58
148
2014/03/11 - 11:40
I'm just downloading it now. Funny I only decided to check out for new ROMs for the M9Pro today after having tried the first PIPO KitKat ROM from their site the other day. I did find a few buggy problems such as flashing screen in some apps and unresponsive buttons. Pure coincidence that I logged on today and saw that the new PIPO update had just gone on line!
Will let you know how I get on.
gemere58
149
2014/03/11 - 12:34
The new update is still 4.2.2! Minus the PIPO launcher. Just exploring and testing but seems ok.... so far
Piperos
Forum Posts: 13
150
2014/03/11 - 14:05
So the update is only for the 3G version?
105 Guest(s)
Devices in use: Desktop (92), Phone (13)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
