(DS1007_M9pro_4.4.2_20131226.rar / M9pro_software_NO 3G_chinese version_20131226_Android4.4.2)
Build information:
Kernel: Linux version 3.0.36+ (york@mid-Porsche) (gcc version 4.4.3 (GCC) ) #386 SMP PREEMPT Wed Dec 25 15:30:50 CST 2013
Android 4.4.2: rockchip/rk3188/rk3188:4.4.2/KOT49H/eng.ljh.20131226.144921:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU version 1.89 (free version)
- increased space for applications (/data partition) to 4 GB
- kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma &Â Crew RKTablets, thank guys!
- optional ClockworkMod (CWM) Recovery easy install package
- Edit 2014/01/14: updated SuperSU to latest version 1.89 (free version)
- Edit 2014/01/14: added Google Experience Launcher (GEL) in addition to PiPO's stock launcher
- Edit 2014/01/14: use optional package to fix broken apps (Contacts/People and Calendar sync)
- Edit 2014/01/29: we have a temporary fix for multi-user support, please check here
Notes:Â
- any update received thru OTA may interfere with our custom firmware, we recommend to refuse any update pushed OTA.Â
Download: kasty-pipo-m9_pro-442-20131226-rooted4c_mu.zip
Please note I haven't tested this firmware yet as I currently don't have my PiPO M9 pro with me during the holidays, please report any problem with this firmware
Edit 2013/01/05: this firmware is confirmed to work by many users in our forum and myself. I have added some screenshots as well.
darevil102, --k0l0kaust0--, hecvalve, cracktech, josedb, saliman2000, nil8ator, maryontour, vasilij0321, prp, tooden, fosforic99, mohr, triusad, 51fiftey, berl1, Piperos, uli-hh, trellosgavros, chichotim, clintc456, scorsby, opuscompu If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/05/15
Look loke we gonna have some work with the end of the year , kitkat or turkey in the plate ?
Tks for work admin
The following users say thank you to DominiqueL for this useful post:
stakon, epsilon79, trellosgavros, giannis1970Cube U30GT2Â Â Â 4.2.2 rooted SDK2.0
Pipo max M9 pro wifi 4.2.2 rooted
Zopo zp 980 Turbo rooted
Asus Zenfone 2
I think PiPO will publish a firmware for the 3G model shortly.
Still, the firmware in post #1 for the WiFI version should also work for 3G models, with 3G function disabled, at least that was working like that on previous firmwares. It even appeared that some WiFI firmware did support the 3G models, so it may be worth trying...
Edit: furonai, you mean you have the 3G model, installed the firmware from post #1 and 3G works ?
hmsr21, darevil102 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/10/26
I think PiPO will publish a firmware for the 3G model shortly.Still, the firmware in post #1 for the WiFI version should also work for 3G models, with 3G function disabled, at least that was working like that on previous firmwares. It even appeared that some WiFI firmware did support the 3G models, so it may be worth trying...
Gonna try it,let you know
2013/11/09
i install the offical pipo rom couple houers ago... work very good and its like clean AOSP, but the gps moudel seems not working.... also all gps test apps on play store canot be installed.... beside that all other working super smooth.
kernel wake-lock issue hym8563 still here
hope this one gonna solve those issues.
thx for rooting.
2013/03/26
Downloaded (fast) and restored onto my Wifi only M9 Pro. Had a few problems initially (crashes & freezes) but I think my external SD card was playing up. Now seems good. But:
GPS is not working. I loaded this ROM and then did load the gps.conf files as for the previous version. Z-Device Test had GPS crossed out (ie no module) and GPS Test showed it as off. In Settings I tried both 'use device (GPS)' and 'High' settings in Location. In previous version I only tried GPS Test but this did show GPS On (& eventually picked up some sats). I could not see any GPS.Config file or other GPS type of file in the root apart from the gps.conf file I had loaded.
The Miracast feature is not working - it does get further than previously - my wifi direct TV sees the Android Tablet, when I start connection the Tablet asks if I agree to the request. The TV then tries to connect but eventually gives up. I will have another try with my bluray player which I think may have Wifi direct as well.
I note the start screen is same as before (saying 4.22) then it goes to the boring 'android' word whilst loading and ends up with the google only launcher. Some of the settings reflect phone and not Tablet and certain files in root mention Nokia and Samsung; I wonder if Pipo have knocked something together in a rush?? Is this simply a 'work in progress' release?
76 Guest(s)
2 Guest(s)
Devices in use: Desktop (71), Phone (3), Tablet (2)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
