[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (version 1.0.7 2013/11/20)
mattiesrag
Forum Posts: 39
Thanks Received: 5
61
2013/12/10 - 13:46
 New ROM out   2013 12 10    Added quickboot   http://pan.baidu.com/s/1ovFmu
Thanks Received: 3170
62
2013/12/10 - 15:10
ludoke
ludoke
Forum Posts: 85
63
2013/12/10 - 15:15
Can you tell me what i have to do to download this?
I got an .exe and all in Chinese and google translate brings me no further.
Please step by step
darevil102
Forum Posts: 35
64
2013/12/10 - 15:32
This is the new update of the japanese ROM. Don't update if you don't want a japanese tablet ;)
darevil102
Forum Posts: 35
65
2013/12/10 - 15:37
Please step by step
http://www.pipo.cn/En/index.php?m=About&a=gujian_show&id=129
Realy you want a chinese ROM??? Don't update if not.
ludoke
Forum Posts: 85
66
2013/12/10 - 15:38
Thank you,i download the 4.2.2 from 2 posts above from admin.
hmsr21
United Kingdom
Forum Posts: 12
67
2013/12/27 - 11:32
mrc_o said
Hi, just downloaded i TS an .IMG file, do i have to copy it in the robot dir or i need the rock chip prog?
Thx
You will need the rockchip program!
http://www.rockchipfirmware.com/sites/default/files/firmware/contributed/RKtool%20_PACKAGE_V1.7english%20language.zip
Pipo M9 Pro WiFi + 3G rooted JB 4.2.2
hmsr21
United Kingdom
Forum Posts: 12
68
2013/12/27 - 12:26
moonwalkie said
ludoke said
RKbatchtool.exe or Finless Rom Flashtool v 1.37
but only through switch button, but when the pipo is not going into bootmode, how can you set it to recovery? RKbatchtool doesn't work when i only connect the pipo, i need to know the commands of the pipo M9 pro for restore mode? there are no buttons!
You need to turn it completely off. Then connect the USB cable to your computer and the USB port on the tablet and press the ESC+Power buttons and stick a paper clip in the reset hole.
This places the tablet in recovery mode and gets recognised as new hardware on your computer.
Then just use the RKTool to flash your new .img ROM.
This is what worked for me. Hope it helps!
hmsr21
United Kingdom
Forum Posts: 12
69
2013/12/27 - 12:40
pablo_gda said
Hi guys
At first i want to apologise for my english.I don't have many situation to use it :)
You do great job by making those firmwares, they are really good.
Frome  last update (firmware frome this topic) i see two troubles.
1. lower perferomence, espicially in mulitask window, when i try to close aplication in memory by movinig it "out of screen"
2. battery life is really really poor
Does someone else have the same problems ?
Yes, I have the same problem where it is using my battery and just allowing me to make use of the tablet on WiFi and drains the tablet after a couple of hours use!
Also, I have graphical degradation where it flickers ocasionally and displays purple lines across the screen when in portrait position.
Does anyone have the same problem? Could this be a firmware related problem or is this hardware failure?
Andi_Berlin
70
2014/01/10 - 00:23
Hi from Berlin,
I´m unable to download from any of the given servers :-(
Download crashes after approx. 200MB, no matter what mirror is choosen.... no resume possible.
Has it somebody handy on his dropbox/hidrive/skydrive/whatever_drive by chance??
thx in advance
Andi
__________________
Solved!
thx to ´cracktech´!
EDHUNTER
Forum Posts: 22
71
2014/02/13 - 01:15
ROM TESTADA NO MEU PIPO MAX-M9 PRO 3G, MUITO BOA MAS APRESENTA INSTABILIDADE NO MENU CONFIGURAÇÕES ... PARABENS AOS DESENVOLVEDORES PELO OTIMO TRABALHO...
Andi_Berlin
72
2014/02/13 - 10:38
________
WHAT ?
griff2
Sarlat
Forum Posts: 11
Thanks Received: 4
73
2014/02/13 - 11:58
EDHUNTER SAID:
ROM TESTED IN MY PIPO MAX PRO-M9 3G, VERY GOOD BUT SHOWS INSTABILITY IN SETTINGS MENU ... CONGRATULATIONS TO THE DEVELOPERS GREAT WORK ...
Or so Google tells me.  ;)
The following users say thank you to griff2 for this useful post:
EDHUNTER
84 Guest(s)
Devices in use: Desktop (75), Phone (9)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
