[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (version 1.0.7 2013/11/20)
BOZ77
Forum Posts: 15
2013/11/25 - 16:09
Hello
then the rom is really great on pipo m9 pro 3g, I advise you to go see the changes that I have made ​​to the build.prop because we find really gain on 3g function, autonomy and fluidity.
thank you again for your work
CybeRNerO
2013/11/26 - 22:55
Excellent work! Well done!
One question to anybody who may knows, is there any way we can deactivate the "Hide feature" of the System bar? It conflicts with Swiftkey. Is there something that I can change in build.prop?
kdaffef
2013/11/27 - 15:52
Hi and big thank for dev team and members,
very nice rom, how i can add sms upgrade to it ??.
griff2
Sarlat
Forum Posts: 11
Thanks Received: 4
2013/11/27 - 17:44
(A little off topic, maybe admin would like it as a new thread?)
AN EASY WAY TO UPDATE THE ROM
I came across some information that suggested it is possible to install a new ROM on the M9Pro (maybe other PIPO products?) by simply placing the update file in the root of the external SD card and renaming it to "update.img".  When you next boot up the M9Pro, the update file is recognised and you are given the opportunity to install it in a pop-up window.
First I tested it whilst my system was (AHEM!) RileyROM2.3   Embarassed and used the official chinese ROM that was released 20/11/13 on my external SD card. I rebooted, and yes, the update was recognised and installed.  During the install the little busy android figure shows along with a sliding scale showing progress of install.  The system seemed to reboot a couple times ... have patience ... and eventually it rebooted into the official Chinese ROM.
Just in case it only worked with the official ROM, I then tested it using the latest Kasty ROM  and rebooted the official version, and it recognised the update file and installed that too.
So it seems to be an easy method, doesn't it?
Maybe other PIPO owners would like to take the bull by the horns and test it out.... (the usual warnings apply... if it bricks it isn't my fault!)
EDIT:  I realise that this method doesn't allow for changing the size of the NAND, but I've been informed that it won't either allow the change of the bootloader (if this is altered in the new ROM) nor the kernel (unless the kernel is in boot.img.)  But still, I think it is worth being aware of.
The following users say thank you to griff2 for this useful post:
Igor101
segundus
2013/11/27 - 18:10
(A little off topic, maybe admin would like it as a new thread?)   AN EASY WAY TO UPDATE THE ROM   I came across some information that suggested it is possible to install a new ROM on the M9Pro (maybe other PIPO products?) by simply placing the update file in the root of the external SD card and renaming it to "update.img".  When you next boot up the M9Pro, the update file is recognised and you are given the opportunity to install it in a pop-up window. First I tested it whilst my system was (AHEM!) RileyROM2.3   Embarassed and used the official chinese ROM that was released 20/11/13 on my external SD card. I rebooted, and yes, the update was recognised and installed.  During the install the little busy android figure shows along with a sliding scale showing progress of install.  The system seemed to reboot a couple times ... have patience ... and eventually it rebooted into the official Chinese ROM. Just in case it only worked with the official ROM, I then tested it using the latest Kasty ROM  and rebooted the official version, and it recognised the update file and installed that too. So it seems to be an easy method, doesn't it? Maybe other PIPO owners would like to take the bull by the horns and test it out.... (the usual warnings apply... if it bricks it isn't my fault!)
Might one ask the source/location of this information.
If correct(and I don't doubt your experience) it seems an incredibly easy way to install without the use of third party tools and the initial hassle of installing drivers,  particularly as Kasty ROM is in the form of "update.img" allready.
Like yourself I am concerned if there are any potential pitfalls, though users seem of the opinion that m9pro is very difficult to brick.
Anyone else have any input?
triusad
2013/11/27 - 18:54
Hi.
I already tested this ROM and it's amazing, very great job!! even solved an issue with my pipo m9 pro 3g, i couldn't turnt it on after turning it off, and had to "restore" the firmware with RKtool to power it up again....thanks!!
Anyway i really like to test the differences in this rom with the original pipo last update, but i cant find the 2013/11/20 update at any pipo webpage.... anyone can give me a link? please
Sorry for my bad english, i'm from canary islands and i had horrible bad english teachers and mainly learned english from "the big bang theory" with subtitles! XD ;)
griff2
Sarlat
Forum Posts: 11
Thanks Received: 4
2013/11/27 - 19:13
@ segundus: I was spending a little time trawling the Chinese forums using Google translator.  Unfortunately such translations aren't really brilliant, but I got the gist of it.  It seems that this method is supported by all Rockchip devices (so I'm told) - but with the limitations I mentioned in my edit.
I agree with you that it seems very hard to brick this unit, which was why I took the plunge and tested out what I thought I had interpreted from the Chinese, and went in both directions.  Going from the official ROM to a custom one was the real risk (I thought), but it seemed all went well with mine.
Igor101
mrc_o
2013/11/28 - 10:40
....so, do i have just to copy the update file in the external sd card?
thx a lot
smudgered
2013/11/28 - 11:33
Has anyone installed the Rom using ARCTOOLS to add CWM functionality?
http://www.arctablet.com/blog/forum/arctools-application/clockworkmod-cwm-recovery-easy-install-on-rk3066-and-rk3188-devices/
If so would they be able to share their experience. I think ARCTOOLS creates the partions for Nand flash,  bootloader and recovery but obviously as there is no documentation other than the video it would be incredibly useful if someone who had used it described how they did it and what happened. (Including for example does it reformat internal sdcard? Does it resize Nand or is that determined by the Rom being installed via ARCTOOLS? - I still can't figure that out... .;=)    )
mrc_o
2013/11/28 - 12:27
...just installed.....but how can i fix the old toolbar? i have always to use  the external button to exit or to go back!!!!
marco
edit:
sorry  x the bar  just  reread the top!!!
hx guys
sms would be great!
josedb
2013/11/29 - 14:59
as i see, the tablet is not entering in deep sleep. its always wake and thats draning battery higher than it should.
mrc_o
2013/11/29 - 21:18
It s notte a rooted ROM? Why after installed gemini ap it says that run only with rotte prvilge? Do i miss something?
Thx
nAFaNyA
2013/12/01 - 08:54
Hihi.
Realy gps better here? (i am now on kasty 2013\10\30)
ludoke
Forum Posts: 85
2013/12/01 - 13:21
Tested this...Not working!!!
I have Riley Rom and i have placed an update.img from Kasty on the root of the Ext.SD card and let the device reboot ,2 times,no result.
Dont't got the notification for installing the img. file
Edit:
Now ,i put the file in the root of the internal memory,reboot...no succes
Igor101
Forum Posts: 18
2013/12/01 - 13:34
Install new ROM from external SD card not working for me also.
Does it only work from the original ROM?
82 Guest(s)
Devices in use: Desktop (73), Phone (9)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
