Here is an Android 4.2.2 Jelly Bean rooted firmware for the PiPO M9 PRO (aka Max-M9pro) for both WiFI and 3G models. This custom firmware is based on new official update version 1.0.7 dated 2013/11/20.Â
(update_M9pro_OTA_1.0.7_20131120.img / M9pro_software_3G&WIFI_english version)
Revision history from the manufacturer:
1. increase hide the status bar featuresÂ
2. HDMI output occasionally interrupt signal to modify the phenomenon.Â
3. Replace pipo launcher apk new version and the corresponding
To hide the status bar, press the last button on the right from the status bar:
From the hidden status bar to show it again: slide from bottom of the screen to the top.
Build information:
Kernel:Â Linux version 3.0.36+ (root@alex-System-Product-Name) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #371 SMP PREEMPT Tue Nov 19 20:51:55 CST 2013
Android 4.2.2 JB:Â rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.root.20131120.141257:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID4.2.2-SDK-v1.04.00
- root with latest SuperSU version 1.75 (free version)
- increased space for applications (/data partition) to 4 GB
- kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma &Â Crew RKTablets, thank guys!
- NEW!  optional ClockworkMod (CWM) Recovery easy install package
Notes:Â
-Â Certificate Center and original PiPO launchers have been kept in the firmware
Download:Â kasty-pipo-m9_pro-422-ota_107_20131120-rooted4.zip
cooltraxx, Paul2482, griff2, josedb, --k0l0kaust0--, fedofed, nik2670, CybeRNerO, mattiesrag, maly2006, triusad, uli-hh, JugeHuge, EDHUNTER If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/11/19
Great stuff!
With 'optional CWM easy Installer' do you mean optionally download arctools app and use that to install instead of flashing with RK Batchtool v 1.7 ? Or have I misunderstood?
Also how is the experience with your M9 Pro? My S2 is running out of app space and I could use more Ram bigger SD etc but am not sure whether to go for M6 Pro 3G or M9 Pro 3G. Have you any views based on your experience?
Going just on spec M6 Pro has bigger battery and can reduce Retina to 1600x1200. Also fewer adverse reports on build quality, wi-fi etc. But M9 Pro maybe has better custom Rom support. Can you add your 2 cents worth?
Igor101 said
Any chance that this rom will be made available in a format that can be flashed by CWM?
It's in the works, future custom firmwares should be released in CWM compatible format as well.
71 Guest(s)
Devices in use: Desktop (60), Phone (11)
alertscam
aolmail7448
Arc123456789
forty42
samih
macsierra2
