[ ROM ] Pipo M9 pro custom root Android 4.2.2 firmware (version 1.0.5 2013/10/30)
mattiesrag
Forum Posts: 39
Thanks Received: 5
31
2013/11/03 - 16:09
Lottoman said
Got a mail from Anna,. Pipo:
The PiPO M9pro_software_3G&WiFi_english version_20131030 is an OTA firmware.
This firmware optimizes the wifi and solve the video call problem of the Skype for M9 pro.
I will ask my workmates to write more details about the firmware next time.
Best regards,
Anna
PiPo Technology Co,.Ltd(digisino group)
website: http://www.pipo.com.cn
Email: anna.ye@pipo.com.cn
Skype: Anna_pipo
YIPPI: Looks like we can get changelogs from now on. That would help a lot to decide for upgrade or not...
Lottoman
Also received a reply from Anna regarding SMS
I am afraid I have no idea about when it wlll be a new SMS updata.
I once downloaded a SMS app in my M9 3G (which is with the NO SMS firmware).
And I tried to spent a short message to my friend, and it worked.
So I think whether you can have a try of this yourself.
Best regards,
Anna
金森数码产品(深圳)有限公司
Skype: Anna_pipo
fernandez
32
2013/11/03 - 20:43
Thanks !
I still was on the first original ROM  of my m9pro uploaded this one using batchtool 1.7, pressing esc+ power during start up,  added manually the driver for my win7 64bi.
Upload was quick and easy  recommended.
Everything seems to work, i hope this one finally takes away all previous wifi issues.
After install I needed to reboot once more, to get connected to wifi.
Igor101
Forum Posts: 18
33
2013/11/03 - 21:14
I don't understand what is happening with SMS.
After installing a previous rom:-
Download: kasty-pipo-m9_pro_3G_SMS-422-20131011-rooted4.zip
SMS worked fine. At least, messages sent to the mobile number associated with the installed SIM card were received and displayed in the default message app.
Why has SMS been dropped from the later release? It seems like a backward step.
futzmaster
Forum Posts: 37
Thanks Received: 4
34
2013/11/03 - 21:43
There were 2 Versions (given from Pipo)...
Admin didn't drop anything...
But as Anna from Pipo said, try an sms app from the store...
(or stay on the other, older version with sms in title if you need it, and wait until pipo gives an update..)
hal rockwell
35
2013/11/03 - 23:00
What option in Titanium Backup am I suppose to use to restore the apps to the state they were before the firmware upgrade?
I used the "Restore Missing Applications and System Data" option and it hung the system and rendered it unbootable after reset so I had to install the rom all over again.
nAFaNyA
36
2013/11/04 - 09:24
Dear admin,
I ask you to add md5 & sha hashes every time when you make new ROM.
Thank you.
Thanks Received: 3171
37
2013/11/04 - 09:28
nAFaNyA,
I wonder why you would need SHA/CRC ? all our firmwares are packaged in zip format that already provides integrity check thru 32 bits CRC when you unpack the file.
Igor101
Forum Posts: 18
38
2013/11/04 - 09:32
Sorry, I didn't mean to sound critical, just trying to understand. Admin is doing a fantastic job, and I am very appreciative of his work with the Pipo. I didn't realise that each new version does not necessarily build on the advances of the previous one.
nAFaNyA
39
2013/11/04 - 09:32
Oh, I see.
I'm sorry, didn't know about that :)  Just I'm always checking my serious downloads like that.
By the way, downloading from America\Russia server (i'm from Russia), speed is about 50kb\s :(
40
2013/11/04 - 09:43
No problem Wink SHA/MD5 will eventually be added at a later time, but CRC32 from the zipfile should protect you for the moment.
As for the download speeds, I'm looking to add another mirror for the East side of the world, either Asia or Russia. Will see if I can get good price on hosting.
Lottoman
Forum Posts: 43
Thanks Received: 10
41
2013/11/04 - 15:22
Lottoman
Forum Posts: 43
Thanks Received: 10
42
2013/11/04 - 15:23
Tiried a few SMS apps from Google store but no go on last Kasty rom.
Lottoman
mattiesrag
Forum Posts: 39
Thanks Received: 5
43
2013/11/04 - 15:40
Lottoman
Saw this on Utube. Supposed to work on all tablets. App available on Playstore.    "Groove IP"
Worth a shot. I cannot try it out as I'm on Kasty sms rom, which works for me untill Pipo release an updated sms rom.
futzmaster
Forum Posts: 37
Thanks Received: 4
44
2013/11/04 - 18:26
Lottoman
Sorry, can't help you with that problem.
Just mentioned again what Anna from Pipo said :)
(mattiesrag posted it too)
@igor101
no need to feel sorry ;)
i think pipo is not really sure what to do...
make 2 versions or 1 :)
45
2013/11/04 - 18:27
Thanks to users contributions in this forum, I'm getting a PiPO M9 Pro 3G in a few days, I'll see if I can help with that SMS issue.
54 Guest(s)
Devices in use: Desktop (52), Phone (2)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
